For my loxone binding i have to change to oracle java.
But i do not know how. Can someone help me.
I followed the steps from here Is oracle java required for insteonplm? Is install via paperui OK? - #6 by tommycw10
I get this:
[12:26:38] openhabian@openHABianPi:~$ sudo apt-get install oracle-java8-jdk
[sudo] password for openhabian:
Reading package lists… Done
Building dependency tree
Reading state information… Done
oracle-java8-jdk is already the newest version (8u65).
The following package was automatically installed and is no longer required:
triggerhappy
Use ‘sudo apt autoremove’ to remove it.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
[14:17:23] openhabian@openHABianPi:~$ sudo update-java-alternatives -s jdk-8-ora cle-arm32-vfp-hflt
update-alternatives: error: no alternatives for jmc
update-alternatives: error: no alternatives for jvisualvm
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/jdk-8-ora cle-arm32-vfp-hflt/bin/jmc
update-java-alternatives: jdk alternative does not exist: /usr/lib/jvm/jdk-8-ora cle-arm32-vfp-hflt/bin/jvisualvm
Thanks for the help
