hi
for openhabian 1.3
which is the right way to update the kernel ?
Ale
hi
for openhabian 1.3
Ale
apt-get dist-upgrade
But as with any major update, make sure you have a backup of your old system ready.
ty mstormi
the command reports : 0 update needed
the kernel 4.9.35 was released on 2017-06-29
how to update on something more recent ?
4.9 would be about right for Jessie, which is an older version Debian (Raspbian). You would need to upgrade to Stretch to use a newer kernel, but this can be an unstable process.
Why are you looking to upgrade?
Right. Please answer Benjyās question first. If you still think you are in need of a newer kernel, Iād suggest to (re)install openHABian on another SD card, starting with the most current image. That one is stretch based which will give you a 4.14 kernel. Then migrate your OH config using openhab-cli backup/restore.
Hallo
Install rpi-update and run rpi-update, this will upgrade the kernel, firmware etc.
Better do not.
Best case nothing will happen but worst case this will install a kernel that the rest of your OS is incompatible with.
Hi Benjy
I think that if the software development has brought from the version .35 to the .134 through corrections, improvements, corrections of corrections, corrections of improvements⦠in a continuous development cycle, this leads me to think that version 4.4.134 is generically ābetterā than 4.4.35
Furthermore, later versions of the kernel reports ābetter support of RPI3 hardwareā and general improvements on filesystem, scheduler and many other parts, this also leads me to think that a version 4.18 is generally ābetterā than a 4.4
Where am I wrong?
Bottom line is openHABian is no general purpose OS but built for use in a specific HW/application combination. You shouldnāt change any of the components unless there is a need to. Belief in āitās betterā is not a need.
You are correct, but itād be up to you weigh the risks of upgrade with its benefits. Since openHABian is a raspbian variant, the way to do this would be the same as debian:
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
Change all instances of jessie
with stretch
in /etc/apt/sources.list
and the directory /etc/apt/sources list.d/
Upgrade the OS
sudo apt update
sudo apt upgrade
http://baddotrobot.com/blog/2017/10/26/upgrade-raspian-jessie-to-stretch/
thank you both
I will evaluate a passage to stretch in the future, for now I stay with the current system
bye
Ale
If I may jump in with a related query here:
My Openhabian 2.3.0-1 running on a Raspi 2 with kernel 4.14.62-v7+ #1134 will not load a module for a USB CSR4.0 device.
On another machine btusb
loads so a FS search shows that btusb is available at
/lib/modules/4.14.79-v7+/kernel/drivers/bluetooth/btusb.ko
/lib/modules/4.14.79+/kernel/drivers/bluetooth/btusb.ko
So should I install a later kernel to get a suitable module or must I go the compile route for a new module?
Hmm, 4.14.62 is pretty up to date (latest ālongtermā is 4.14.82) so must be something fairly experimental you want to use I guess. Honestly I donāt know what to advise. I wouldnāt risk breaking things so Iād go compile. Or clone your system and try on another box first.
Thanks Markus. A reboot was required to get the bluetooth utils working and now btusb is registered and device is working. No compiling required.
