It’s still broken. I can’t attach the log (new user). Latest lines:
2020-04-06_12:40:22_CEST [openHABian] Adding slightly tuned vim config file to system… OK
2020-04-06_12:40:22_CEST [openHABian] Downloading and setting up FireMotD… OK
2020-04-06_12:41:47_CEST [openHABian] Installing Java Zulu 32-Bit OpenJDK… OK
2020-04-06_12:43:10_CEST [openHABian] Installing or upgrading to latest openHAB release (stable)… Warning: apt-key output should not be parsed (stdout is not a terminal)
gpg: no valid OpenPGP data found.
FAILED (apt)
2020-04-06_12:43:21_CEST [openHABian] Initial setup exiting with an error!
I understand that this is not all.
I sequentially executed the commands from the file /boot/first-boot.bash after the command if (/bin/bash /opt/openhabian/openhabian-setup.sh unattended); then.
Now I think what to do next.
Ok, I see it from another computer.
Can I restart RPi or need something else?
Those who had used openhabian-config to complete their installation, please also reboot (your box should repeat installing unless you have removed /opt/openHABian-install-failed)
While it might have apparently worked, there’s a number of things to miss because of premature termination of the automatic install run.
