What do you mean by retry ? Just reboot ?
I have started a new installation and it seems to be working now.
I still get the gpg-error, but as you described in the #821-thread on github, it does not terminate the installation.
I will let you know if I find any problems.
Thanks a lot for fast help.
UPDATE:
The first SD card which I have tried the different solutions (add - x etc.) worked fine when I did a reboot. But when I tried the new card with the same original image on, it failed with error FAILED(apt) instead of FAILED(key).
Ok, it seems to go a step urther, will wait until it’s done
2020-04-03_12:37:41_CEST [openHABian] Installing Java Zulu 32-Bit OpenJDK... OK
2020-04-03_12:39:31_CEST [openHABian] Installing or upgrading to latest openHAB release (stable)... Warning: apt-key output should not be parsed (stdout is not a terminal)
gpg: no valid OpenPGP data found.
OK
2020-04-03_12:40:22_CEST [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... Replacing... OK
YES !!! it worked
Unfortunatelly, it is the same for me…
does your box have proper internet access?
I’m not sure how I confirm internet access? I see it on the network, responds to the local ping request.
However, I can not reach it from the browser with the domain name, only with the local IP.
SSH works (that’s the way I get the error log)
2020-04-03_16:28:26_CEST [openHABian] Downloading and setting up FireMotD… OK <
Does this mean it has internet access?
Now I have got it to work on a new install.
- Installed with fresh card and image -> FAILED(apt)
- Did all the changes @mstormi suggested above, i.e. comment the line “if git …” and putting -x in some files (see above)
- Rebooted and waited for the installation to finish.
Now it works!
Probably but not necessarily.
But when you can login using SSH, you can diagnose that (ping, wget)
Or try executing sudo openhabian-config
. Not guaranteed it works at that half-baked stage but worth a try. Try option 03 or 41 to install openhab2, that’s probably where @pacjo and you were stuck.
(and add that -x to openhab.bash
before, see above, to get debug output)
Sorry to throw in a stupid question from a guy that only has very little Linux knowledge: where to find openhab.bash?
I have still problems with the installation
Now:
2019-07-10_01:21:34_BST [openHABian] Starting the openHABian initial setup.
2019-07-10_01:21:34_BST [openHABian] Storing configuration... OK
2019-07-10_01:21:34_BST [openHABian] Starting webserver with installation log... OK
2019-07-10_01:21:40_BST [openHABian] Changing default username and password... OK
2019-07-10_01:21:47_BST [openHABian] Setting up Wi-Fi connection... OK, rebooting...
2019-07-10_01:22:01_BST [openHABian] Starting the openHABian initial setup.
2019-07-10_01:22:01_BST [openHABian] Storing configuration... OK
2019-07-10_01:22:01_BST [openHABian] Starting webserver with installation log... OK
2019-07-10_01:22:06_BST [openHABian] Changing default username and password... SKIPPED
2019-07-10_01:22:06_BST [openHABian] Setting up Wi-Fi connection... OK
2019-07-10_01:22:10_BST [openHABian] Ensuring network connectivity... OK
2019-07-10_01:22:10_BST [openHABian] Waiting for dpkg/apt to get ready... OK
2020-04-03_15:17:27_BST [openHABian] Updating repositories and upgrading installed packages... OK
2020-04-03_15:21:41_BST [openHABian] Installing git package... OK
2020-04-03_15:21:59_BST [openHABian] Cloning myself... OK
2020-04-03_15:22:01_BST [openHABian] Executing 'openhabian-setup.sh unattended'...
2020-04-03_15:22:01_BST [openHABian] Checking for root privileges... OK
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists...
2020-04-03_15:22:05_BST [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-04-03_15:22:05_BST [openHABian] Setting timezone based on openhabian.conf... OK (Europe/Berlin)
2020-04-03_16:22:05_CEST [openHABian] Setting locale based on openhabian.conf... OK
2020-04-03_16:22:43_CEST [openHABian] Setting hostname of the base system... OK
2020-04-03_16:22:43_CEST [openHABian] Setting the GPU memory split down to 16MB for headless system... OK
2020-04-03_16:22:43_CEST [openHABian] Enabling Audio output... OK
2020-04-03_16:22:44_CEST [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2020-04-03_16:23:52_CEST [openHABian] Installing additional needed packages... OK
2020-04-03_16:24:37_CEST [openHABian] Adding slightly tuned bash config files to system... OK
2020-04-03_16:24:37_CEST [openHABian] Adding slightly tuned vim config file to system... OK
2020-04-03_16:24:37_CEST [openHABian] Downloading and setting up FireMotD... OK
2020-04-03_16:25:38_CEST [openHABian] Installing Java Zulu 32-Bit OpenJDK... OK
2020-04-03_16:26:29_CEST [openHABian] Installing or upgrading to latest openHAB release (stable)... Warning: apt-key output should not be parsed (stdout is not a terminal)
FAILED (apt)
2020-04-03_16:26:37_CEST [openHABian] Initial setup exiting with an error!
2020-04-03_16:24:40_CEST [openHABian] Starting the openHABian initial setup.
2020-04-03_16:24:40_CEST [openHABian] Storing configuration... OK
2020-04-03_16:24:40_CEST [openHABian] Starting webserver with installation log... OK
2020-04-03_16:24:45_CEST [openHABian] Changing default username and password... SKIPPED
2020-04-03_16:24:45_CEST [openHABian] Setting up Wi-Fi connection... OK
2020-04-03_16:24:49_CEST [openHABian] Ensuring network connectivity... OK
2020-04-03_16:24:49_CEST [openHABian] Waiting for dpkg/apt to get ready... 2020-04-03_17:02:05_CEST [openHABian] Starting the openHABian initial setup.
2020-04-03_17:02:05_CEST [openHABian] Storing configuration... OK
2020-04-03_17:02:05_CEST [openHABian] Starting webserver with installation log... OK
2020-04-03_17:02:10_CEST [openHABian] Changing default username and password... SKIPPED
2020-04-03_17:02:10_CEST [openHABian] Setting up Wi-Fi connection... OK
2020-04-03_17:02:14_CEST [openHABian] Ensuring network connectivity... OK
2020-04-03_17:02:14_CEST [openHABian] Waiting for dpkg/apt to get ready...
With a new SD-Card the first boot up Failed, after a restart it hangs up on Step
after ‘Cleanup of Temporary Directories’
I waited one hour but nothing changed.
Has anybody a working solution?
This one works!
I run sudo openhabian-config, then option 3 and it’s up and running.
Even after a shutdown the system is coming back, and is accessible.
Thank you!
Thanks Markus!
That did the trick
Have a beautiful weekend!
Thanks, Markus.
Have a nice weekend.
Best regards from Warstein
Hello, can everyone post the Code from the files with the “-x” ?
Can anyone help me ?
File:
/opt/openhabian/functions/openhab.bash
string:
if ! cond_redirect apt-get ${APT_INST_OPTS} install “openhab2=${openhabVersion}”; then echo “FAILED (apt)”; exit 1; fi
What needs to be fixed?
Now it works!
This ??
Conducted an experiment.
File /opt/openhabian/openhab.bash, string 47.
If wget save to file “-” (stdout):
sudo wget --no-check-certificate -O - ‘Service End for Bintray, JCenter, GoCenter, and ChartCenter | JFrog’ | apt-key add -
then:
[ <=> ] 0 --.-KB/s per 0s
Unable to write to «-» (Channel break).
If wget saves to file “111”:
sudo wget --no-check-certificate -O /home/openhabian/111 ‘Service End for Bintray, JCenter, GoCenter, and ChartCenter | JFrog’ | apt-key add /home/openhabian/111
then:
/home/openhabian/111 [ <=> ] 3,14K --.-KB/s per 0,001s
2020-04-05 07:45:12 (5,61 MB/s) - «/home/openhabian/111» saved [3219]
New to [openHABian], I had this issue. Executing sudo openhabian-config
and using option 03 worked for me. Thanks
Anyone, can you please state if installing straight from image works now.
If no where does it break ? Send /boot/first-boot.log
Note selecting option 03 in openhabian-config will execute the same code that unattended install failed in.
… because you did not prefix the 2nd command (after the pipe) with “sudo”
