OpenHABian install file sync errors?
[SOLVED] I’m a moron and was using too big of an SD card.
This may be more of a general Linux question, but I’d figure I’d give it a shot:
I’m attempting to do a fresh install on a RPi3, it performs all the retrieving and verifying, and then moves to configuration steps. It’s then failing with a bunch of “unable to sync file” errors and then just shutting down.
Any tips on how to fix this?
Thanks!My Google-fu is weak and I’ve been unable to find anything that points to these errors.
Never saw that before. Please check what I’ve written here: http://docs.openhab.org/installation/openhabian.html#faq-successful
Too big SD card?? :slight_smile:
64GB . . . apparently the Pi’s will only reliably work on a 32GB or
smaller? So says the internet.
Ah, yes there is that problem -.-
http://elinux.org/RPi_SD_cards#Working_.2F_Non-working_SD_cards
