Platform information:
- Hardware: Raspberry Pi 3 A+
- OS: openHABian 1.5
- Java Runtime Environment: which java platform is used and what version
- openHAB version: openhabian-pi-raspbian-201908050414-gitca0976f-crc6a66b5a1.img.xz
Issue of the topic: Installation of openHABian ends with an error. I tried multiple times. What is the problem with the openhabian User? I hope someone can help me with that problem. Thanks.
Installation log:
2020-02-24_16:48:02_GMT [openHABian] Storing configuration... OK
2020-02-24_16:48:02_GMT [openHABian] Starting webserver with installation log...OK
2020-02-24_16:48:23_GMT [openHABian] Changing default username and password... SKIPPED
2020-02-24_16:48:26_GMT [openHABian] Setting up Ethernet connection... OK
2020-02-24_16:48:26_GMT [openHABian] Ensuring network connectivity... OK
2020-02-24_16:48:28_GMT [openHABian] Waiting for dpkg/apt to get ready... OK
2020-02-24_16:49:28_GMT [openHABian] Updating repositories and upgrading installed packages... OK
2020-02-24_17:10:21_GMT [openHABian] Installing git package... OK
2020-02-24_17:11:37_GMT [openHABian] Cloning myself... OK
2020-02-24_17:11:49_GMT [openHABian] Executing 'openhabian-setup.sh unattended'...
2020-02-24_17:11:49_GMT [openHABian] Checking for root privileges... OK
Hit:1 http://archive.raspberrypi.org/debian buster InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian buster InRelease
Reading package lists...
2020-02-24_17:12:00_GMT [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2020-02-24_17:12:02_GMT [openHABian] Setting timezone based on IP geolocation... FAILED
2020-02-24_17:14:39_GMT [openHABian] Setting locale based on openhabian.conf... OK
2020-02-24_17:16:12_GMT [openHABian] Setting hostname of the base system... OK
2020-02-24_17:16:14_GMT [openHABian] Installing basic can't-be-wrong packages (screen, vim, ...)... OK
2020-02-24_17:19:29_GMT [openHABian] Installing additional needed packages... OK
2020-02-24_17:20:43_GMT [openHABian] Adding slightly tuned bash config files to system... cp: cannot create regular file '/home/openhabian/.bash_profile': No such file or directory
chown: invalid user: âopenhabian:openhabianâ
OK
2020-02-24_17:20:55_GMT [openHABian] Adding slightly tuned vim config file to system... OK
2020-02-24_17:20:55_GMT [openHABian] Downloading and setting up FireMotD... grep: /home/openhabian/.bash_profile: No such file or directory
/opt/openhabian/functions/packages.bash: line 35: /home/openhabian/.bash_profile: No such file or directory
OK
2020-02-24_17:23:01_GMT [openHABian] Installing Java Zulu 32-Bit OpenJDK... OK
2020-02-24_17:25:48_GMT [openHABian] Installing or upgrading to latest openHAB release (stable)... OK
2020-02-24_17:28:00_GMT [openHABian] Adding an openHAB dashboard tile for 'openhabiandocs'... OK
2020-02-24_17:28:00_GMT [openHABian] Adding openHAB syntax to vim editor... chown: invalid user: âopenhabian:openhabianâ
OK
2020-02-24_17:28:01_GMT [openHABian] Adding openHAB syntax to nano editor... OK
2020-02-24_17:28:02_GMT [openHABian] Adding openHAB scheme to multitail... OK
2020-02-24_17:28:02_GMT [openHABian] Preparing openHAB folder mounts under /srv/... OK
2020-02-24_17:28:03_GMT [openHABian] Applying file permissions recommendations... OK
2020-02-24_17:28:06_GMT [openHABian] Applying miscellaneous system settings... chown: invalid user: âopenhabian:openhabianâ
Creating persistent systemd journal folder location: /var/log/journal
Keeping at most 30 days of systemd journal entries
Deleted archived journal /run/log/journal/122b114983d941dab77ac21a9b900f92/system@5f483e09a3c74dbcbdd914a05f48aba5-0000000000000001-00058d48a7cef4c1.journal (2.6M).
Vacuuming done, freed 2.6M of archived journals from /run/log/journal/122b11498d941dab77ac21a9b900f92.
OK
2020-02-24_17:28:06_GMT [openHABian] Setting up Samba network shares... Failed to add entry for user openhabian.
OK
2020-02-24_17:32:37_GMT [openHABian] Installing Node.js for arm (prerequisite for other packages)... OK
2020-02-24_17:33:53_GMT [openHABian] Installing the openHAB Log Viewer (frontail) relative to nodejs base /usr/lib... OK
2020-02-24_17:35:20_GMT [openHABian] Adding an openHAB dashboard tile for 'frontail'... OK
2020-02-24_17:35:20_GMT [openHABian] Execution of 'openhabian-setup.sh unattended' completed.
2020-02-24_17:35:20_GMT [openHABian] Waiting for openHAB to become ready...1..2..3..4..5..6..7..8..9..10..11..12..13..14..15..16..17..18..19..20..failed.
