there seems to be something wrong with the openhabian-config i guess.
I have installed everything 5 times from the scratch and everytime it is the same
Influxdb does not work giving authorization problems and errors. Fresh installs everytime and using the config-tool
i tried OH2.4, 2.5 etc… something is wron either with the installation script or the influx installation…
2019-04-17 15:44:29.654 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.10:8080
2019-04-17 15:44:29.671 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.10:8443
2019-04-17 15:44:31.302 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2019-04-17 15:44:33.221 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-04-17 15:44:33.391 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.10:8080
2019-04-17 15:44:33.393 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.10:8443
2019-04-17 15:50:42.371 [thome.event.ExtensionEvent] - Extension 'package-expert' has been installed.
2019-04-17 15:51:13.239 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2019-04-17 15:51:15.783 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2019-04-17 15:51:15.929 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2019-04-17 15:51:16.722 [thome.event.ExtensionEvent] - Extension 'misc-restdocs' has been installed.
2019-04-17 15:51:16.735 [thome.event.ExtensionEvent] - Extension 'transformation-javascript' has been installed.
2019-04-17 15:51:16.739 [thome.event.ExtensionEvent] - Extension 'ui-habpanel' has been installed.
2019-04-17 15:51:16.741 [thome.event.ExtensionEvent] - Extension 'transformation-regex' has been installed.
2019-04-17 15:51:16.742 [thome.event.ExtensionEvent] - Extension 'transformation-jsonpath' has been installed.
2019-04-17 15:51:16.744 [thome.event.ExtensionEvent] - Extension 'transformation-xpath' has been installed.
2019-04-17 15:51:16.745 [thome.event.ExtensionEvent] - Extension 'ui-basic' has been installed.
2019-04-17 15:51:16.747 [thome.event.ExtensionEvent] - Extension 'transformation-map' has been installed.
2019-04-17 15:51:16.748 [thome.event.ExtensionEvent] - Extension 'ui-classic' has been installed.
2019-04-17 15:51:16.750 [thome.event.ExtensionEvent] - Extension 'ui-habmin' has been installed.
2019-04-17 15:51:16.752 [thome.event.ExtensionEvent] - Extension 'transformation-xslt' has been installed.
2019-04-17 15:51:16.753 [thome.event.ExtensionEvent] - Extension 'transformation-exec' has been installed.
2019-04-17 15:51:16.755 [thome.event.ExtensionEvent] - Extension 'ui-paper' has been installed.
2019-04-17 15:51:16.756 [thome.event.ExtensionEvent] - Extension 'transformation-scale' has been installed.
2019-04-17 15:54:02.893 [thome.event.ExtensionEvent] - Extension 'binding-zwave' has been installed.
2019-04-17 15:54:22.875 [thome.event.ExtensionEvent] - Extension 'persistence-influxdb' has been installed.
2019-04-17 16:01:22.494 [ERROR] [nternal.extensions.ExtensionResource] - Exception while installing extension: No extension service registered for influxdb
2019-04-17 16:01:22.514 [thome.event.ExtensionEvent] - influxdb: No extension service registered for influxdb
2019-04-17 16:01:24.177 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2019-04-17 16:01:24.272 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.10:8080
2019-04-17 16:01:24.274 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.10:8443
2019-04-17 16:42:24.884 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
java.lang.RuntimeException: {"error":"authorization failed"}
at org.influxdb.impl.InfluxDBErrorHandler.handleError(InfluxDBErrorHandler.java:19) ~[241:org.openhab.persistence.influxdb:1.13.0]
at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:242) ~[241:org.openhab.persistence.influxdb:1.13.0]
at org.influxdb.impl.$Proxy135.writePoints(Unknown Source) ~[241:org.openhab.persistence.influxdb:1.13.0]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:151) ~[241:org.openhab.persistence.influxdb:1.13.0]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:171) [241:org.openhab.persistence.influxdb:1.13.0]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:144) [241:org.openhab.persistence.influxdb:1.13.0]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:?]
2019-04-17 16:42:28.955 [vent.ItemStateChangedEvent] - ZWaveSerialController_FramesAcknowledged changed from 42 to 43
2019-04-17 16:42:28.988 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
if i change user to admin in influxdb.cfg i get:
2019-04-17 17:03:00.421 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
java.lang.RuntimeException: {"error":"database not found: \"openhab_db\""}
it seems that the db is not even created!!!
installing influxdb manually works ok… Jesus i had a lot to learn those couple of days…
but please fix it
