It seems that openhabian-config
gained some new features for copying SD cards. (At least I only just noticed those features for the first time). Apart from text of the menu items, is there some documentation about those new features?
SD card mirroring has been there for quite some years now (since at least 2.5 according to the older versions of the docs).
Theres a lengthy section in the openHABian docs that discusses it: openHABian | openHAB and it mentioned is several places in the openHABian docs. Is there some question you have not answered by those? We can answer and update the docs if so.
Ok. Got it thanks. Note that the doc contains a couple of internal links to #SD-mirroring (mixed case) which are broken because the actual link should be to #sd-mirroring (lowercase)
Should be:
Good find! I just did a search and didn’t click the links.
Could you create a quick issue on the openHABian repo so it’s not forgotten? I would but I’m about to run to an appointment and I’m afraid I’ll forget when I get back.
