After downloading a new Openhabian to SD-card (I want to migrate from OH3.4 to 4, made back-up and started with new SD to build up from scratch) I noticed some issues with installing Zigbee2MQTT. I’m running:
openHABian Configuration Tool — [openHAB3]{2023-08-16T21:49:21+02:00}(292689e)
openHAB 3.4.5 - Release Build
When selecting 20 - 2A (install or update Zigbee2MQTT) there are no zigbee USB devices shown.
Reading a little further this seems to be no problem from Openhabian, but from Bullseye as also discussed in this post https://discourse.openhab.org/t/new-sd-install-openhab4-but-no-zigbee-adapter/148796. I do have devices ‘by-path’ but not ‘by-id’.
ls -l /dev/serial/by-path
total 0
lrwxrwxrwx 1 root root 13 Sep 24 11:58 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-port0 -> ../../ttyUSB1
lrwxrwxrwx 1 root root 13 Sep 24 11:58 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-port0 -> ../../ttyUSB0
But not by-id:
ls -l /dev/serial/by-id
ls: cannot access '/dev/serial/by-id': No such file or directory
There’s a discussion in this topic below how to solve it. But if I follow this, I will divert from the stock Openhabian I love Openhabian because it takes care of a lot of the Linux stuff I don’t fully understand and. Is this being implementend in the Openhabian? Any advice what to d?
https://github.com/Koenkk/zigbee2mqtt/issues/17535#issuecomment-1532469360
