Openhabian OH3 Upgrade doesnt complete
I am completely new to Openhab and I just started experimenting with openhabian on a
Raspberry Pi Model B 4GB RAM
a few days ago. Yesterday I saw that Openhab 3.0 is on the verge of being realease and thus I tried giving it a shot and tried to upgrade my Openhab 2 Installation practically empty according to the documentation.
I installed putty connected to my pi with it and then started the upggrade.
Java 11 installs fine. But then Nothing happened when installing the OpenHAB 3 update for over 2h.
Thus I thought maybe I did something wrong and reflashed the sd card and installed openHabian again. This worked fine. Directly after install, as a first action I connected via putty to the Pi and started the upgrade again. Thus far with the same result.
Since about 1h stuck at
2020-12-06_18:30:58_CET [openHABian] Installing selected openHAB version…
Any Idea what I can do?
Regards,
Matt
2020-12-06_18:01:00_CET [openHABian] Checking for root privileges… OK
2020-12-06_18:01:00_CET [openHABian] Loading configuration file ā€˜/etc/openhabian.conf’… OK
2020-12-06_18:01:00_CET [openHABian] openHABian configuration tool version: [stable]v1.6.1-963(1fa8959)
2020-12-06_18:01:00_CET [openHABian] Checking for changes in origin branch stable… OK
2020-12-06_18:01:08_CET [openHABian] Switching to branch stable… OK
2020-12-06_18:01:17_CET [openHABian] Updating Linux package information… OK
2020-12-06_18:01:17_CET [openHABian] Preparing openHAB installation… OK
2020-12-06_18:01:22_CET [openHABian] Beginning openHAB backup… SKIPPED
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following packages will be REMOVED:
openhab2 openhab2-addons
0 upgraded, 0 newly installed, 2 to remove and 0 not upgraded.
After this operation, 294 MB disk space will be freed.
(Reading database … 53348 files and directories currently installed.)
Removing openhab2-addons (2.5.10-1) …
Removing openhab2 (2.5.10-1) …
Processing triggers for systemd (241-7~deb10u4+rpi1) …
Updating FireMotD available updates count …
2020-12-06_18:02:08_CET [openHABian] WARNING: We were unable to detect Java 11 on your system so we will install the openHABian default (Zulu 11).2020-12-06_18:02:10_CET [openHABian] Installing Java Zulu prerequisites (libc, libstdc++, zlib1g)… OK
2020-12-06_18:02:20_CET [openHABian] Downloading Java Zulu 11 32-Bit OpenJDK… OK
2020-12-06_18:03:21_CET [openHABian] Installing Java Zulu 11 32-Bit OpenJDK… OK
2020-12-06_18:03:28_CET [openHABian] Installing Java Zulu CEK to enable unlimited cipher strength… OK
2020-12-06_18:03:29_CET [openHABian] Installing openHAB… 2020-12-06_18:03:29_CET [openHABian] Beginning install of latest openHAB3 milestone release (testing)… OK
2020-12-06_18:30:56_CET [openHABian] Adding required keys to apt… OK
is that the highest debug level that is available in openhabian-config ?
If not startup with debugging as described in the openhabian docs: https://github.com/openhab/openhabian/blob/master/docs/openhabian-DEBUG.md#debug
You need to set
debugmode=on
in /etc/openhabian.conf. Then you’ll see what is going wrong while installing openHab.
Had the same issue and followed the instructions:
Debug mode was set to on in /etc/openhabian.conf
During failed update to OH3 it instructed to run sudo dpkg --configure -a manually.
Did so and confirmed to change config files back to maintainers version (ā€˜I’ or ā€˜Y’)
Afterwards the update to OH3 went through, still some errors but it looks like it installed.
thank you for your assistance and sorry for the late reply but I just got back to tryout today.
I reflashed the openhab 2 image, updated the openhab 2 Version. It worked fine.
Afterwards as a nearly total linux novice it took me some time until i managed to start bash and edit the config file to debug mode on. But finally that worked as well.
Then I started the upgrade to openhab 3 again. And now I could see much more information and I had to choose file overrides serveral times I confirmed all with ā€œYā€ and finally it said that openhab 3 was succesfully installed.
I got a prompt from the openhabian-config:
ā€œError of execution: 40 | openhab relatedā€
The server hasn’t been accessible via Browser yet, but I will give it a few more minutes.
Thanks for your help.
Matt
Ok, unfortunately openhab 3 server seems to not come available.
I found the logs on the console - and its says that it doesnt find the right java Version (see below). But the Java install during the upgrade didnt show any errors. Any Ideas?
[15:26:36] openhabian@openHABianDevice:~$ sudo openhab-cli showlogs
==> /var/log/openhab/audit.log <==
… 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core.karaf/3.0.0.M5: missing requirement [org.openhab.core.karaf/3.0.0.M5] osgi.wiring.package; filter:=ā€œ(&(osgi.wiring.package=org.openhab.core)(version>=3.0.0)(!(version>=4.0.0)))ā€ [caused by: Unable to resolve org.openhab.core/3.0.0.M5: missing requirement [org.openhab.core/3.0.0.M5] osgi.ee; filter:=ā€œ(&(osgi.ee=JavaSE)(version=11))ā€]
at org.apache.felix.resolver.Candidates$MissingRequirementError.toException(Candidates.java:1343) ~[org.eclipse.osgi-3.12.100.jar:?]
… 12 more
Caused by: org.apache.felix.resolver.reason.ReasonException: Unable to resolve org.openhab.core/3.0.0.M5: missing requirement [org.openhab.core/3.0.0.M5] osgi.ee; filter:=ā€œ(&(osgi.ee=JavaSE)(version=11))ā€
… 12 more
Ok, I dont know exactly what I did - but finally openhab 3 became available in the browser.
Thus I am allright for the time being.
Thx again for pointing me towards the debug mode. That did the job.
