Does anyone know if it’s possible to run OpenHABian in Virtualbox running on a windows PC?
I have a windows box that runs 24/7 and it’s currently got OpenHAB 2 running on it. But I’d like to use OpenHABian but not on a raspberry pi because of all the SD card issues etc etc.
Could you explain the reasons you want to run openhabian on x86?
I don’t think this is possible without emulating the cpu, because of different architecture. And emulating a cpu is always slow.
I did run openhab for some time on ubuntu linux. Debian based as well, so similar to openhabian. Switched to openhabian when i separated the server functions.
OpenHABian itself might be possible, but you have to emulate the Raspi.
But you can run a “normal” OH2 on a virtual machine. I run a virtualbox on an Intel NUC. But: if you need some direct attached “Things” it might be difficult. I, for example, have some problems with the z-wave USB Stick: it doesn’t work reliable but I haven’t time to gather the problem yet.
My configuration:
Intel NUC 7i7BNH
Host: Windows 10
VirtualBox (runnig as a service with NSSM) with lateat ubuntu server
I’m pretty sure you can use openhabian on whatever hardware (or emulated) as long as you are using debian/ubuntu as OS. see http://docs.openhab.org/installation/openhabian.html#faq-other-platforms
afaik openhabian does not require special functions of Raspberry, but of course you can’t extend memory of a non-existing sd-card…
openHABian is just a set of scripts that automation the installation and configuration of a Debian based OS. You can use openHABian to configure anything from Raspbian running on a RPi to Ubuntu 17 in a VM.
And if you want as close as an experience to Raspbian as possible, there is an x86 version of Raspbian available from the RPi organization’s website.
I guess I just want something “stable” that isn’t going to get file system corruption.
My windows based machine has been perfect but the upgrading of OpenHAB on Windows seems to be not as well documented and easy as it is with OpenHABian.
