I have openhab 2.2 running on windows for some time and have found it to work very well. I decided to switch to running on the Pine64 and installed the openhabianpine64 image, selected the demo setup option, seemed to be a good installation. Booting the openhabianpine64 image installs the stable release of OpenHAB so I Used openhabian-config to switch to the openhab 2.2 release. The console login banner shows openHAB 2.2.0~20171119011223-1 (Build #1083). Finding the following errors on openhab.log. Any suggestions would be appreciated.
After posting this I shutdown the Pine64 and now it seems to fail to boot up!
2017-11-18 20:31:56.986 [ERROR] [org.eclipse.smarthome.core.audio ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.audio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.audio [110]
Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:="optional"
Unresolved requirement: Import-Package: org.osgi.service.http
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1620) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1599) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1571) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1514) [?:?]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]
2017-11-18 20:31:57.036 [ERROR] [org.eclipse.smarthome.core.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.voice [119]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.audio
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-symbolic-name="org.eclipse.smarthome.core.audio"; bundle-version="0.9.0.201711182209"; version="0.0.0"
2017-11-18 20:31:57.044 [ERROR] [org.eclipse.smarthome.io.javasound ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.javasound
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.javasound [122]
2017-11-18 20:31:57.052 [ERROR] [org.eclipse.smarthome.io.net ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.net
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.net [124]
2017-11-18 20:31:57.060 [ERROR] [org.eclipse.smarthome.io.rest.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.voice
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.rest.voice [131]
Unresolved requirement: Import-Package: org.eclipse.smarthome.io.rest
-> Export-Package: org.eclipse.smarthome.io.rest; bundle-symbolic-name="org.eclipse.smarthome.io.rest"; bundle-version="0.9.0.201711182209"; version="0.0.0"
org.eclipse.smarthome.io.rest [125]
Unresolved requirement: Import-Package: org.glassfish.jersey.server
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.voice
-> Export-Package: org.eclipse.smarthome.core.voice; bundle-symbolic-name="org.eclipse.smarthome.core.voice"; bundle-version="0.9.0.201711182209"; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.voice.text
-> Export-Package: org.eclipse.smarthome.core.voice.text; bundle-symbolic-name="org.eclipse.smarthome.core.voice"; bundle-version="0.9.0.201711182209"; version="0.0.0"
2017-11-18 20:31:57.104 [ERROR] [org.eclipse.smarthome.io.webaudio ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.webaudio
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.io.webaudio [133]
2017-11-18 20:31:57.113 [ERROR] [org.eclipse.smarthome.model.core ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.core
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.core [134]
Unresolved requirement: Import-Package: org.eclipse.xtext.common.types.impl
Unresolved requirement: Import-Package: com.google.inject
-> Export-Package: com.google.inject; bundle-symbolic-name="com.google.inject"; aop="false"; bundle-version="3.0.0.v201312141243"; version="1.3.0"
com.google.inject [24]
Unresolved requirement: Import-Package: javax.inject
2017-11-18 20:31:57.120 [ERROR] [org.eclipse.smarthome.model.rule ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule [142]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.core
-> Export-Package: org.eclipse.smarthome.model.core; bundle-symbolic-name="org.eclipse.smarthome.model.core"; bundle-version="0.9.0.201711182209"; version="0.0.0"
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.script
-> Export-Package: org.eclipse.smarthome.model.script; bundle-symbolic-name="org.eclipse.smarthome.model.script"; bundle-version="0.9.0.201711182209"; version="0.0.0"
org.eclipse.smarthome.model.script [145]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.persistence.extensions
-> Export-Package: org.eclipse.smarthome.model.persistence.extensions; bundle-symbolic-name="org.eclipse.smarthome.model.persistence"; bundle-version="0.9.0.201711182209"; version="0.0.0"
org.eclipse.smarthome.model.persistence [139]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.items
-> Export-Package: org.eclipse.smarthome.model.items; bundle-symbolic-name="org.eclipse.smarthome.model.item"; bundle-version="0.9.0.201711182209"; version="0.0.0"
org.eclipse.smarthome.model.item [135]
Unresolved requirement: Import-Package: org.eclipse.smarthome.model.script.engine.action
-> Export-Package: org.eclipse.smarthome.model.script.engine.action; bundle-symbolic-name="org.eclipse.smarthome.model.script"; bundle-version="0.9.0.201711182209"; version="0.0.0"
2017-11-18 20:31:57.134 [ERROR] [eclipse.smarthome.model.rule.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.rule.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.rule.runtime [144]
-> Export-Package: org.eclipse.smarthome.model.script.engine; bundle-symbolic-name="org.eclipse.smarthome.model.script"; bundle-version="0.9.0.201711182209"; version="0.0.0"
2017-11-18 20:31:57.148 [ERROR] [org.eclipse.smarthome.model.script ] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script [145]
2017-11-18 20:31:57.168 [ERROR] [lipse.smarthome.model.script.runtime] - FrameworkEvent ERROR - org.eclipse.smarthome.model.script.runtime
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.script.runtime [147]
Unresolved requirement: Require-Bundle: org.eclipse.smarthome.model.script
-> Bundle-SymbolicName: org.eclipse.smarthome.model.script; bundle-version="0.9.0.201711182209"; singleton:="true"
2017-11-18 20:32:07.100 [ERROR] [ternal.service.BootFeaturesInstaller] - Error installing boot features
java.lang.IllegalStateException: Resource has no uri
at org.apache.karaf.features.internal.service.Deployer.getBundleInputStream(Deployer.java:1457) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:763) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1248) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$1(FeaturesServiceImpl.java:1147) ~[?:?]
2017-11-18 20:44:30.946 [ERROR] [org.eclipse.smarthome.core.audio ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.audio
2017-11-18 20:44:31.004 [ERROR] [org.eclipse.smarthome.core.voice ] - FrameworkEvent ERROR - org.eclipse.smarthome.core.voice
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340) [?:?]your code
