hi everybody,
i am just trying openhabian for the first time, so far i used openhab on windows.
i could install it without any problem (3.2.0) on a rp4 with 4gb ram. i decided to use a 128gb ssd i already had. installation worked fine, booting from usb…
after that i tried to install sd mirroring on a 32 gb sd card getting this error:
2022-02-05_19:04:57_CET [openHABian] Setting up automated SD mirroring and backup... blockdev: cannot open /dev/mmcblk0: No such file or directory
sfdisk: cannot open /dev/mmcblk0: No such file or directory
Checking that no-one is using this disk right now ... OK
Disk /dev/sdb: 29.72 GiB, 31914983424 bytes, 62333952 sectors
Disk model: Storage Device
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xcc1075e3
Old situation:
Device Boot Start End Sectors Size Id Type
/dev/sdb1 2048 62332927 62330880 29.7G 6 FAT16
>>> Created a new DOS disklabel with disk identifier 0x0a998c27.
/dev/sdb1: Start sector 0 out of range.
Failed to add #1 partition: Numerical result out of range
Leaving.
is the problem the different size of ssd and sd ?
thankful for any help for a beginner !!!
thanks
