Is there a way to find out, which specific tasks consume CPU-power?
Since a few days or weeks (?) I notice sometimes very slow behaviour of my openHABian (RPI 3, 1.3 openHABian, 2.1 stable). I suspect some configuration, which causes some CPU-Needs…
Specifically if I save some files (.rules or .items, …) it sometimes takes up to 3min to process the new configuration. Usually I get a direct Response in the logs “Refreshing model XY”, but now if I save a file, it could take some minutes until the refreshing is done. It also has some unwanted side effects for Actions I’d like to have, especially if using the http-binding, this also will be postponed.
So I’d like to see which process Needs CPU, top
only gives my something like this:
ok, I see the JAVA and Python runtimes need much time. I assume, JAVA is openHAB an Python is a script I use to read out my heating Controller.
[19:28:50] openhabian@openHABianPi:~$ top
top - 19:45:02 up 6:50, 1 user, load average: 0,31, 0,65, 0,72
Tasks: 126 total, 1 running, 125 sleeping, 0 stopped, 0 zombie
%Cpu(s): 41,3 us, 3,0 sy, 0,0 ni, 55,7 id, 0,0 wa, 0,0 hi, 0,1 si, 0,0 st
KiB Mem: 994236 total, 530528 used, 463708 free, 38388 buffers
KiB Swap: 102396 total, 0 used, 102396 free. 165472 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
19813 openhab 20 0 504536 270012 28328 S 161,3 27,2 63:49.96 java
7480 openhab+ 20 0 24728 8660 5268 S 7,6 0,9 0:00.23 python
6504 openhab+ 20 0 5708 2560 2124 R 0,7 0,3 0:07.77 top
139 root 20 0 10232 3120 2860 S 0,3 0,3 0:02.52 systemd-journal
407 root 20 0 32140 2692 2324 S 0,3 0,3 0:00.53 rsyslogd
701 openhab 20 0 125080 31464 17684 S 0,3 3,2 0:41.33 node
6912 root 20 0 0 0 0 S 0,3 0,0 0:00.05 kworker/2:2
7473 root 20 0 6444 2284 1980 S 0,3 0,2 0:00.01 cron
1 root 20 0 5544 3972 2736 S 0,0 0,4 0:04.06 systemd
2 root 20 0 0 0 0 S 0,0 0,0 0:00.02 kthreadd
3 root 20 0 0 0 0 S 0,0 0,0 0:04.95 ksoftirqd/0
5 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/0:0H
7 root 20 0 0 0 0 S 0,0 0,0 0:28.21 rcu_sched
8 root 20 0 0 0 0 S 0,0 0,0 0:01.83 rcu_bh
9 root rt 0 0 0 0 S 0,0 0,0 0:00.31 migration/0
10 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 lru-add-drain
11 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/0
12 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/1
13 root rt 0 0 0 0 S 0,0 0,0 0:00.26 migration/1
14 root 20 0 0 0 0 S 0,0 0,0 0:00.24 ksoftirqd/1
16 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/1:0H
17 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/2
18 root rt 0 0 0 0 S 0,0 0,0 0:00.19 migration/2
19 root 20 0 0 0 0 S 0,0 0,0 0:01.08 ksoftirqd/2
21 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/2:0H
22 root 20 0 0 0 0 S 0,0 0,0 0:00.00 cpuhp/3
23 root rt 0 0 0 0 S 0,0 0,0 0:00.25 migration/3
24 root 20 0 0 0 0 S 0,0 0,0 0:00.30 ksoftirqd/3
26 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kworker/3:0H
27 root 20 0 0 0 0 S 0,0 0,0 0:00.00 kdevtmpfs
28 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 netns
29 root 20 0 0 0 0 S 0,0 0,0 0:00.04 khungtaskd
30 root 20 0 0 0 0 S 0,0 0,0 0:00.00 oom_reaper
31 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 writeback
32 root 20 0 0 0 0 S 0,0 0,0 0:00.00 kcompactd0
33 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 crypto
34 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
35 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kblockd
36 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 watchdogd
38 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 rpciod
39 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 xprtiod
40 root 20 0 0 0 0 S 0,0 0,0 0:00.00 kswapd0
41 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 vmstat
42 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 nfsiod
52 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 kthrotld
53 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
54 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
55 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
56 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
57 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
58 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
59 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
60 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
61 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
62 root 0 -20 0 0 0 S 0,0 0,0 0:00.00 bioset
