Openhabian: system upgrade (02) failed because /mount/firmware was not available
I started the upgrade system in openhabian (menu 02). I see a lot of unpacking lines, then a lot of setting lines, then many setting up lines.
Setting up userconf-pi (0.10) ...
Setting up libpython3.11-dev:arm64 (3.11.2-6+deb12u5) ...
Setting up openjdk-17-jre-headless:arm64 (17.0.14+7-1~deb12u1) ...
Installing new version of config file /etc/java-17-openjdk/jfr/default.jfc ...
Installing new version of config file /etc/java-17-openjdk/jfr/profile.jfc ...
Installing new version of config file /etc/java-17-openjdk/net.properties ...
Installing new version of config file /etc/java-17-openjdk/security/default.policy ...
Installing new version of config file /etc/java-17-openjdk/security/java.policy ...
Installing new version of config file /etc/java-17-openjdk/security/java.security ...
Installing new version of config file /etc/java-17-openjdk/security/public_suffix_list.dat ...
Setting up ssh (1:9.2p1-2+deb12u4) ...
Setting up python3.11-dev (3.11.2-6+deb12u5) ...
Processing triggers for man-db (2.11.2-2) ...
Processing triggers for dbus (1.14.10-1~deb12u1) ...
Processing triggers for debianutils (5.7-0.5~deb12u1) ...
Processing triggers for mailcap (3.70+nmu1) ...
Processing triggers for libc-bin (2.36-9+rpt2+deb12u9) …
Processing triggers for initramfs-tools (0.142+rpt3+deb12u1) ...
update-initramfs: Generating /boot/initrd.img-6.6.20+rpt-rpi-v8
**raspi-firmware: missing /boot/firmware, did you forget to mount it?**
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return code 1
dpkg: error processing package initramfs-tools (--configure):
 installed initramfs-tools package post-installation script subprocess returned error exit status 1
Processing triggers for ca-certificates-java (20230710~deb12u1) ...
done.
Errors were encountered while processing:
 raspi-firmware
 initramfs-tools
Updating FireMotD available updates count ...
E: Sub-process /usr/bin/dpkg returned an error code (1)
W: Operation was interrupted before it could finish
FAILED
2025-02-14_18:26:14_CET [openHABian] Checking for default openHABian username:password combination... OK
2025-02-14_18:26:14_CET [openHABian] We hope you got what you came for! See you again soon ;)
openhabian@openhabian:~ $
I started with these system status :
##   Release = Debian GNU/Linux 12 (bookworm)
##    Kernel = Linux 6.6.20+rpt-rpi-2712
##    Memory = Free: 2.17GB (28%), Used: 5.79GB (72%), Total: 7.86GB
##      Swap = Free: 2.99GB (100%), Used: 0.00GB (0%), Total: 2.99GB
##      Root = Free: 20.49GB (74%), Used: 6.98GB (26%), Total: 28.69GB
##   Updates = 137 apt updates available.
       openHAB 4.2.1 - Release Build
It is a fresh installation of bookworm (around 1 year ago).
I found some hints that there shall be an error with system upgrade, but my fstab already had the correct content.
But: the devices from fstab (/boot/firmware) were not mounted!
I ran ‘mount -a’ and the folder was mounted.
I started again openhabian menu 02, but it ran very short and did nearly ‘nothing’, but I don’t know if it is all done now. At least I expect that openhab will also be updated.
openhabian@openhabian:~ $ sudo openhabian-config
2025-02-14_19:01:21_CET [openHABian] Checking for root privileges... OK
2025-02-14_19:01:21_CET [openHABian] Making sure router advertisements are available... OK
2025-02-14_19:01:21_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2025-02-14_19:01:21_CET [openHABian] openHABian configuration tool version: [openHAB]{2025-02-03T13:58:34-07:00}(6f5beda)
2025-02-14_19:01:21_CET [openHABian] Checking for changes in origin branch openHAB... OK
2025-02-14_19:01:22_CET [openHABian] Switching to branch openHAB... OK
2025-02-14_19:01:22_CET [openHABian] Checking openHAB Signing Key expiry.
2025-02-14_19:01:22_CET [openHABian] Checking expiry date of apt keys... OK
2025-02-14_19:01:32_CET [openHABian] Updating Linux package information... OK
2025-02-14_19:01:32_CET [openHABian] Updating repositories and upgrading installed packages...
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages have been kept back:
  libcamera-ipa linux-headers-rpi-2712 linux-headers-rpi-v8 linux-image-rpi-2712 linux-image-rpi-v8 raspi-config raspi-utils rpi-eeprom rpicam-apps-lite
0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
2 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Setting up initramfs-tools (0.142+rpt3+deb12u1) ...
update-initramfs: deferring update (trigger activated)
Setting up raspi-firmware (1:1.20241126-1) ...
'/boot/vmlinuz-6.6.20+rpt-rpi-2712' -> '/boot/firmware/kernel_2712.img'
'/boot/vmlinuz-6.6.20+rpt-rpi-v8' -> '/boot/firmware/kernel8.img'
'/boot/initrd.img-6.6.20+rpt-rpi-v8' -> '/boot/firmware/initramfs8'
update-initramfs: Generating /boot/initrd.img-6.6.20+rpt-rpi-2712
'/boot/initrd.img-6.6.20+rpt-rpi-2712' -> '/boot/firmware/initramfs_2712'
2025-02-14_19:02:10_CET [openHABian] Checking for default openHABian username:password combination... OK
2025-02-14_19:02:10_CET [openHABian] We hope you got what you came for! See you again soon ;)
2025-02-14_19:02:42_CET [openHABian] Checking for root privileges... OK
2025-02-14_19:02:42_CET [openHABian] Making sure router advertisements are available... OK
2025-02-14_19:02:42_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2025-02-14_19:02:42_CET [openHABian] openHABian configuration tool version: [openHAB]{2025-02-03T13:58:34-07:00}(6f5beda)
2025-02-14_19:02:42_CET [openHABian] Checking for changes in origin branch openHAB... OK
2025-02-14_19:02:43_CET [openHABian] Switching to branch openHAB... OK
2025-02-14_19:02:43_CET [openHABian] Checking openHAB Signing Key expiry.
2025-02-14_19:02:43_CET [openHABian] Checking expiry date of apt keys... OK
2025-02-14_19:02:52_CET [openHABian] Updating Linux package information... OK
2025-02-14_19:02:52_CET [openHABian] Updating repositories and upgrading installed packages...
2025-02-14_19:03:16_CET [openHABian] Updating Linux package information... OK
2025-02-14_19:03:16_CET [openHABian] Updating repositories and upgrading installed packages...
2025-02-14_19:03:22_CET [openHABian] Checking for default openHABian username:password combination... OK
2025-02-14_19:03:22_CET [openHABian] We hope you got what you came for! See you again soon ;)
I have these questions:
  1. Has anyone an idea, why the /boot/firmware/ was not mounted? Has it to do with active ZRAM?
  2. How can I now proceed? I have the feeling, that not all system updates have been finished (I’m not experienced with Linux). So I don’t want to start openhab upgrade to 4.3 in this state.
    Thanks for help!
Answering question 2 by myself: seems all has been done, because I see openHAB 4.3.2 as current running version.
Still confusing: in the Putty terminal I see still updates available:
 Updates = 154 apt updates available.
