as long my OH 1.8.3 is running, still with some problems due to “no autostart after reboot”, I’m playing with OH2 to migrate soon…
But after install/setup openHABian V1.3, I’ve no access to the samba-shares.
As I understood, openHABian is comming along with a pre-configured samba-shares (user/passwrd -> openhabian/openhabian)
Windows 10 Explorer shows me the network host “openhabianpi”, but when I try to access it, I get a “no access” errorcode 0x80070035
following the whole Error-Dialog (sorry for german Windows-Version!)
[Window Title]
Netzwerkfehler
[Main Instruction]
Auf \\OPENHABIANPI konnte nicht zugegriffen werden.
[Content]
Vergewissern Sie sich, dass der Name richtig geschrieben wurde. Möglicherweise besteht ein Netzwerkfehler. Klicken Sie auf "Diagnose", um die Netzwerkprobleme zu identifizieren und zu beheben.
[^] Details ausblenden [Diagnose] [Abbrechen]
[Expanded Information]
Fehlercode: 0x80070035
Der Netzwerkpfad wurde nicht gefunden.
I’m not sure, if I have to setup some settings manually?!
You should not have to configure anything manually. You can force the issue though. You can ssh to the RPi and run openhabian-conf and change the Samba user and password from there.
After installing 3 times the image (OpenHabian V1.3) on 2 different SD-Cards, with no effect. Tried with 2 diffrent Windows 10 PC to connect the Samba shares… No effect!
Right know I changed the hardware!!!
I changed my 2 system CD-Cards:
Live-Image (OH 1.8.3) running on a Raspi 3
with
Dev-Image (OH2 OpenHabian 1.3) running on a Raspi 2
That means, I boot the new OH2 now on the Raspberry 3 and the productive SD-Image on the Raspberry 2.
Know the samba shares are available for the OH2 (on Raspi 3) and the productive-system OH 1.8.3 (on Raspi 2)!
So, I assume that there is an issue with the samba-configuration OpenHabian V1.3 for or with Raspberry 2?!
How can I check and fix this??
