1.I flashed a new SD card with openhabian 1.7.5
2. first openhab installation seems to be fine
3. I can’t login via ssh with the default user openhabian:openhabian
Does anyone have any ideas?
Dirk
Dirk
See
let me know if “habopen” works as the password
Sorry, I reverted to 1.7 and then did the update to 1.7.5. can’t test it anymore unfortunately. This was the fastest way for me.
After a new installation of grafana and influxdb, same issue: wrong credentials.
That statement does not make sense as there is no openHABian 1.7 or any means to “revert” to an earlier version.
Whatever, I fixed 1.7.5 the password should be “openhabian” again now.
Thanks a lot Markus!
