I cannot install frontail using the openHABian UI. I think it is due to the fact that my user is not openhabian as I changed it in the openhabian.conf file before I booted my pi.
This is what I get when I try
$ useradd --groups openhabian,openhab -s /bin/bash -d /var/tmp frontail
useradd: group 'openhabian' does not exist
FAILED (adduser)
Apologies, I was not being lazy I was just unsure what information you required upfront.
Yes
Sorry, maybe I’m not understanding correctly but on a previous custom install of openhab I used to be able to see the log in the browser but now I cannot. ip.address:9001 I could also just click it along with grafana, habpanel etc in the dashboard found at ip.address:8080
After I put the image on the sd card I opened the boot partition and edited the user and password in the openhabian.conf
I’ll update and debug maximum and try again thanks
frontail should be installed by default if you run the image so you must not install again.
What does journalctl -xu frontail.service say?
Did you try the master branch (clonebranch=master during installation) ?
Never mind you would need a different image.
It’s (probably) fixed there. For the time being (stable branch) I think you cannot have both, frontail and a changed user.
Great. There are 2 more that need updating at the bottom of the page.
So where is the log for future reference? I can see the first boot one is /boot/first-boot.log but what about after a successful install to DEBUG issues like I was having.
