Got a brend new Raspberry pi, flashed a SD-card started, let the Raspberry start an it all went fine.
Image used: openhabianpi-raspbian-201706161358-git7ff273e-crc00389b9f.img.xz
Logged onto http://openhabianpi:8080 and chose Expert setup and then checked the log:
[ERROR] [org.eclipse.smarthome.io.rest.sse ] - FrameworkEvent ERROR - org.eclipse.smarthome.io.rest.sse
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-misc-restdocs, openhab-transformation-javascript, openhab-ui-habpanel, openhab-transformation-regex, openhab-transformation-jsonpath, openhab-transformation-xpath, openhab-ui-basic, openhab-transformation-map, openhab-ui-classic, openhab-ui-habmin, openhab-transformation-xslt, openhab-transformation-exec, openhab-ui-paper, openhab-transformation-scale': Error restarting bundles
After this I reflashed the image and chose Standard setup. This time it worked fine no errors in log. Don’t know if I really need the Expert setup, but there are some openhab1 bindings (modbus) I definitely need. So should I care about the Expert setup or just continue with the Standard setup?
Either way, this should be fixed.
