I noticed on a recent upgrade that the log folder is no longer included in the default openHABian Samba setup, and within the configuration file it says corruption will occur if the log folder portion is uncommented. My question is, does this apply to Raspberry PI installations only, or all Linux installations? I’ve setup a small x86 Linux server running Debian Buster using openHABian and would like to uncomment the log portion if it won’t cause corruption. Any guidance is appreciated.
Yes. Sorry for troubling you. I finally found it myself, but only after searching the whole machine (and failing) for openhab or samba until I cottoned on to smb
