Openhub gives 404
I have a Debian server running OpenHAB. Everything was working fine until I performed a Debian update and rebooted the server. Since then, I get a 404 error when I try to access the OpenHAB URL. The server itself is running and accessible via SSH. OpenHAB seems to be running as well, as I can access it through the CLI. Port 8080 is also being used by OpenHAB.
First let me Welcome you to the community,
Let’s try and get a bit more clarity here.
Can we assume the title should be OpenHaB gives 404 and not Openhub gives 404? not sure what Openhub would be but regardless how about providing more info.
What version of Debian are you running?
What version of OpenHaB are you running
what version of Java are you running?
What component of Debian did you specifically do a update on?
Have you confirmed that whatever update you did has not reset firewalls or blocked your port 8080
Have you reviewed the openhab.log or event logs for any error messages or other clues?
Provide some additional info here and folks will have a better chance at assisting you.
Take a screenshot of the 404 page. Is it served by openhab, or by another process already listening on the same port?
What is the URL that you tried?
