Hey,
I’m just wanting to share a few ideas/solutions to cut on your energy bill if you happen to have a photovoltaic system installed.
Use PV Energy for Rollershutters
This first snippet does the following when triggered:
- The current (average) state of the rollershutters is evaluated
- If mostly down, the rollershutters will go up and vice versa
- If there is no more power than 150W (Base load of the house) all rollershutters are driven at once as grid power will be used in any case
- Otherwise the power going to the grid is taken as a base and then divided by (generously rounded up) 200W for each rollershutter
- The determined count of concurrent rollershutters will be driven, the next delayed by tRS, 25 seconds
// JGZentral = Group:Number:AVG JGZentral "State Rollershutters" <rollershutter>
// J_Zentral = Rollershutter J_Zentral "All Rollershutters"
// J_Flur, J_Kuche... = Rollershutter J_Kuche "Kitchen" (JGZentral) { knx="3/0/2, 3/1/2, 3/2/2+3/3/2" }
// PWR_Generation = Number item, Power generation from PV
// PWR_FeedIn = Number item, Electricity going to the grid
import org.eclipse.smarthome.model.script.ScriptServiceUtil
var delay=0
var target = DOWN
var Number tNum = 0
var Number nParallel = 1
var Number i = 1
val Number tRS = 25
if (JGZentral.state < 0.5) target = DOWN
else target = UP
if (target == DOWN) tNum = 100
else tNum = 0
// Decide to drive all at once
if (PWR_Generation.state > 150) {
nParallel = Math::floor((PWR_FeedIn.state as Number).doubleValue / 200)
if (nParallel < 1) nParallel = 1
logInfo("Eco-Rollo", "nParallel: "+nParallel)
for (String Jal : newArrayList('J_Flur', 'J_Kuche', 'J_Ess_E', 'J_Ess_S', 'J_LH_U', 'J_Woh_S', 'J_Woh_W', 'J_LH_O')) {
val Jal = ScriptServiceUtil.getItemRegistry.getItem(Jal)
if (Jal.state != tNum) {
createTimer(now.plusSeconds(delay)) [|
Jal.sendCommand(target)
if (i == nParallel) {
delay = delay + tRS
Thread::sleep(100)
i = 0
i += 1
} else {
J_Zentral.sendCommand(target)
I really hope this is understandable ![]()
If not, please feel free to ask.
