Options for adding Fibaro FGR223 on OH 2.4
HI All
Trying to add this device, Type/ID 0303:3000 which appears to not be supported by the 2.5.0 ZWave binding.
What options are available to use this device on OH2.4? Ive been using org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar for some time (2.5.0.201908050054), without issue , can I simply drop the new jar in there for 2.5.8 (or 2.5.13 which appears the latest Maven) which is what OpenSmartHouse Z-Wave Device Database is showing me has the devices info in it
Cheers
If you already have a 2.5 SNAPSHOT binding working on 2.4 you likely could upgrade to the latest 2.5 SNAPSHOT using the same install script.
Zigbee and Z-Wave manual install script - Tutorials & Examples - openHAB Community
Cool thanks Bruce, yep i’m using 2.5.0 from back in August 2019 it appears. I guess I can drop the jar in there - the network is huge so it just takes aggggeeees to come back up (ZWave that is)
@chris is 2.5.0-SNAPSHOT.jar (2.5.0.201908050054) vastly different to the latest 2.5.x binding?
There are a few changes, but not too much. Of course the database will be very different.
Thats cool - I’ll give it a go. Yep, the database being different is a good thing - more support for new devices! Thanks gents
You will also need to delete & re-add the Thing to OH to get the new database settings.
Is there any reason you have not moved to at least 2.5.x?
Because 2.4 is so rock solid :slight_smile: and I can’t see any major compelling reason. The house hasn’t changed, except a device here and there, so it’s only the DB updating that provides real value to me.
Hi Chris
It doesnt appear to work, the ZStick comes online but no devices will
I deleted the Stick thing and also the node, same issue. The good news, is the node 190 it didnt understand before, it now understands but wont add that node into the list - just sits in the inbox
The node I was adding that wasnt in the DB, was node 190. I added it from the inbox which triggered this, but it wont add in either.
09:30:07.474 [WARN ] [org.eclipse.jetty.server.HttpChannel ] - /rest/inbox/zwave:device:6dad8bea:node190/approve/
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/eclipse/smarthome/config/core/ConfigDescriptionBuilder
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
        at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
        at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
        at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
        at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/eclipse/smarthome/config/core/ConfigDescriptionBuilder
        at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[?:?]
        at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[?:?]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[?:?]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[?:?]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[?:?]
        at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[?:?]
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[?:?]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[?:?]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[?:?]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[?:?]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[?:?]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[?:?]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[?:?]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[?:?]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[?:?]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[?:?]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[?:?]
        at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[?:?]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[?:?]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[?:?]
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
        ... 15 more
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org/eclipse/smarthome/config/core/ConfigDescriptionBuilder
        at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[?:?]
        at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[?:?]
        at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[?:?]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[?:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[?:?]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[?:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[?:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[?:?]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[?:?]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[?:?]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[?:?]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[?:?]
        at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[?:?]
        ... 15 more
Caused by: java.lang.NoClassDefFoundError: org/eclipse/smarthome/config/core/ConfigDescriptionBuilder
        at org.openhab.binding.zwave.internal.ZWaveConfigProvider.getConfigDescription(ZWaveConfigProvider.java:149) ~[?:?]
        at org.eclipse.smarthome.config.core.ConfigDescriptionRegistry.fillFromProviders(ConfigDescriptionRegistry.java:215) ~[?:?]
        at org.eclipse.smarthome.config.core.ConfigDescriptionRegistry.getConfigDescription(ConfigDescriptionRegistry.java:183) ~[?:?]
        at org.eclipse.smarthome.config.core.ConfigDescriptionRegistry.getConfigDescription(ConfigDescriptionRegistry.java:237) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.getConfigDescParams(PersistentInbox.java:586) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.getConfigDescParams(PersistentInbox.java:580) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.getPropsAndConfigParams(PersistentInbox.java:554) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.approve(PersistentInbox.java:157) ~[?:?]
        at org.eclipse.smarthome.io.rest.core.internal.discovery.InboxResource.approve(InboxResource.java:104) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
        at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[?:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[?:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[?:?]
        at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[?:?]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[?:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[?:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[?:?]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[?:?]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[?:?]
        ... 15 more
AND
09:48:40.271 [WARN ] [ommon.WrappedScheduledExecutorService] - Scheduled runnable ended with an exception:
        at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.synchronizeConfiguration(PersistentInbox.java:229) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.add(PersistentInbox.java:211) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.thingDiscovered(PersistentInbox.java:345) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl$1.run(DiscoveryServiceRegistryImpl.java:264) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl$1.run(DiscoveryServiceRegistryImpl.java:1) ~[?:?]
        at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
        at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.thingDiscovered(DiscoveryServiceRegistryImpl.java:261) ~[?:?]
        at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.thingDiscovered(AbstractDiscoveryService.java:281) ~[?:?]
        at org.openhab.binding.zwave.discovery.ZWaveDiscoveryService.deviceAdded(ZWaveDiscoveryService.java:234) ~[?:?]
        at org.openhab.binding.zwave.discovery.ZWaveDiscoveryService$1.run(ZWaveDiscoveryService.java:88) ~[?:?]
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) ~[?:?]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266) ~[?:?]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) ~[?:?]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) ~[?:?]
I think this is caused by changes that were made in the core which has added requirements and made the binding incompatible.
Damn. Do you know which version would work in the 2.5.x branch that would still work? I was using an earlier 2.5.0 without issues.
Or is there a way to find older version m say 2.5.8? I cant seem to find those jars
It appears to be time to move away from OH 2.4.you cannot expect developers to test compatibility that far back. There have been too many major architectural changes in OH even between 2.4 & 2.5.
I dont expect them to, never asked that.
But upgrading 2.4 to 2.5 or even 3 - sorry but neither of those versions have anywhere near the stability of 2.4.
There wasnt even a stable 2.5 released
2.5 has has a stable core for over a year. Only the various bindings have been updated.
