Org.openhab.core.persistence:3.0.1 throws exception because of DayOfMonth = 0 in cron expression '0 0 0 0 * ?'
Dear Community,
A few days ago, I activated the persistence service on OpenHAB 3.0.1 with InfluxDB 1, installed via Openhabian. It basically works, but each time when OpenHAB starts, I find the following exception in the log file:
2021-03-26 13:03:26.855 [ERROR] [org.openhab.core.persistence        ] - bundle org.openhab.core.persistence:3.0.1 (184)[org.openhab.core.persistence.internal.PersistenceManagerImpl(224)] : The addPersistenceService method has thrown an exception
java.lang.IllegalArgumentException: Value too small in range in cron expression '0 0 0 0 * ?' in field 'DayOfMonth': value 0, minimum: 1
Is this an effect because storing data in the InfluxDB started later than March 1 in this month? Is this an error message that requires attention?
Best regards,
Peter
I think this may be to do with the persist settings, as in “everyMonth” or something. Do you have a influxdb.persist file or are you relying on the “default to everything”?
my influxdb.persist contains the following settings:
Strategies {
    everyQuarterHour : "0 0,15,30,45 * * * ?"
    everyHour : "0 0 * * * ?"
    everyDay  : "0 0 0 * * ?"
    everyMinute  : "0 0 0 0 * ?"
    default = everyChange
Items {
    * : strategy = everyChange, everyQuarterHour
Best regards,
Peter
The error message was caused by a wrong cron expression:
Which should read:
everyMinute  : "0 * * * * ?"
After correcting this, the error was gone.
