Orvibo and Openhabian python socket error
I was able to setup Orvibo using following tutorial
I was able to test it from command lines too…
I was able to setup TV remote on and off with orvibo using your guide. It worked initially later on during testing I found its not working now.
Initially, it was working from command line.
[20:56:10] openhabian@Raiba-SmartHome:/etc/openhab2/orvibo$ python3 orvibo.py -m accf234f82a6 -x irda -e test-TV-off.ir
Orvibo[type=irda, ip=Unknown, mac=accf234f82a6]
Emit IR done.
[20:57:13] openhabian@Raiba-SmartHome:/etc/openhab2/orvibo$ python3 orvibo.py -m accf234f82a6 -x irda -e test-TV-on.ir
Emit IR done.
Later on, I tried the same from .items and sitemap it was not working.
hence I tried again from command prompt and it started giving below error.
getting below errors
[21:33:11] openhabian@Raiba-SmartHome:/etc/openhab2/orvibo$ python3 orvibo.py -i 192.168.1.103 -x irda -e test-TV-on.ir
Traceback (most recent call last):
  File "orvibo.py", line 715, in <module>
    d = Orvibo.discover(o.ip)
  File "orvibo.py", line 330, in discover
    with _orvibo_socket() as s:
  File "/usr/lib/python3.4/contextlib.py", line 59, in __enter__
    return next(self.gen)
  File "orvibo.py", line 135, in _orvibo_socket
    sock = _create_orvibo_socket() if external_socket is None else external_socket
  File "orvibo.py", line 130, in _create_orvibo_socket
    sock.bind((ip, PORT))
OSError: [Errno 98] Address already in use
[20:46:10] openhabian@Raiba-SmartHome:/etc/openhab2/services$ netstat -an | grep 1000
udp6    3072      0 :::10000                :::*
[21:11:12] openhabian@Raiba-SmartHome:/etc/openhab2/services$
[21:11:12] openhabian@Raiba-SmartHome:/etc/openhab2/services$ sudo echo 30 > /proc/sys/net/ipv4/tcp_fin_timeout
-bash: /proc/sys/net/ipv4/tcp_fin_timeout: Permission denied
[21:20:37] openhabian@Raiba-SmartHome:/etc/openhab2/services$
[20:45:23] openhabian@Raiba-SmartHome:/etc/openhab2/services$ netstat -an
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
tcp        0    280 192.168.1.130:22        192.168.1.100:61169     ESTABLISHED
tcp        0      0 192.168.1.130:1883      192.168.1.107:14184     ESTABLISHED
tcp        0      0 127.0.0.1:1883          127.0.0.1:48188         ESTABLISHED
tcp        0      0 192.168.1.130:445       192.168.1.100:61127     ESTABLISHED
tcp        0      0 192.168.1.130:22        192.168.1.100:61177     ESTABLISHED
tcp        0      0 192.168.1.130:1883      192.168.1.109:9162      ESTABLISHED
tcp6       0      0 :::139                  :::*                    LISTEN
tcp6       0      0 :::5007                 :::*                    LISTEN
tcp6       0      0 :::8080                 :::*                    LISTEN
tcp6       0      0 :::22                   :::*                    LISTEN
tcp6       0      0 :::8443                 :::*                    LISTEN
tcp6       0      0 :::1883                 :::*                    LISTEN
tcp6       0      0 :::445                  :::*                    LISTEN
tcp6       0      0 127.0.0.1:43711         :::*                    LISTEN
tcp6       0      0 :::9124                 :::*                    LISTEN
tcp6       0      0 127.0.0.1:8101          :::*                    LISTEN
tcp6       0      0 192.168.1.130:37060     139.162.171.235:443     ESTABLISHED
tcp6       0      0 192.168.1.130:37054     139.162.171.235:443     ESTABLISHED
tcp6       0      0 192.168.1.130:8080      192.168.1.100:61174     ESTABLISHED
tcp6       0      0 192.168.1.130:37056     139.162.171.235:443     ESTABLISHED
tcp6       1      0 192.168.1.130:8080      192.168.1.100:61171     CLOSE_WAIT
tcp6       0      0 192.168.1.130:37046     139.162.171.235:443     ESTABLISHED
tcp6       0      0 192.168.1.130:37042     139.162.171.235:443     ESTABLISHED
tcp6       0      0 192.168.1.130:37052     139.162.171.235:443     ESTABLISHED
tcp6       0      0 192.168.1.130:8080      192.168.1.100:61153     ESTABLISHED
tcp6       0      0 127.0.0.1:48188         127.0.0.1:1883          ESTABLISHED
tcp6       0      0 192.168.1.130:37040     139.162.171.235:443     ESTABLISHED
udp        0      0 0.0.0.0:5353            0.0.0.0:*
udp        0      0 0.0.0.0:49433           0.0.0.0:*
udp        0      0 0.0.0.0:68              0.0.0.0:*
udp        0      0 192.168.1.130:123       0.0.0.0:*
udp        0      0 127.0.0.1:123           0.0.0.0:*
udp        0      0 0.0.0.0:123             0.0.0.0:*
udp        0      0 192.168.1.255:137       0.0.0.0:*
udp        0      0 192.168.1.130:137       0.0.0.0:*
udp        0      0 0.0.0.0:137             0.0.0.0:*
udp        0      0 192.168.1.255:138       0.0.0.0:*
udp        0      0 192.168.1.130:138       0.0.0.0:*
udp        0      0 0.0.0.0:138             0.0.0.0:*
udp6       0      0 :::5353                 :::*
udp6       0      0 192.168.1.130:38205     :::*
udp6       0      0 :::40789                :::*
udp6       0      0 :::1900                 :::*
udp6       0      0 fe80::d516:2dfb:f4a:123 :::*
udp6       0      0 ::1:123                 :::*
udp6       0      0 :::123                  :::*
raw6       0      0 :::58                   :::*                    7
Realise this is very old now, but I have the same issue. Did you solve it?
Steve
