Hi all,
I followed the steps at Home · openhab/openhab1-addons Wiki · GitHub
but at the last step I don’t know how to acces OSGI console. I run openHAB as a service, And I can’t find start scripts. ![]()
Hi all,
Try to telnet the OSGI Console,
telnet localhost 5555
Thomas
it doesn’t work for me, but maybe I use it in a wrong way:
pi@raspberrypi ~ $ telnet localhost 5555
-bash: telnet: command not found
The telnet executable is probably not installed. You can install it via: sudo apt-get install telnet
Best regards, Chris.
I had a big problem with this as well… specifically because the version I setup the Dropbox binding had disabled the OSGi console for some technical reason.
My work around was just to tail the OpenHAB log file live, so it was essentially acting as the console.
tail -f /var/log/openhab/openhab.log
