- Platform information:
- Hardware: Raspi 4, 2 GB RAM, 16 GB SD card
- OS: openhabian (OH3)
- Java Runtime Environment: OpenJDK Runtime Environment Zulu11.52+13-CA (build 11.0.13+8-LTS)
- openHAB version: 1.7.1
- Issue of the topic:
I connected the power outlet (OSRAM LEDVANCE AB3257001NJ) via zigbee successfully. Displaying the state (ON/OFF) works fine. However if I configure to set the switch there is no reaction. I can see in the log of Mosquitto that the command does not reach there.
The outlet state item is defined as:
channelTypeUID: mqtt:switch
label: State(E003)
description: ""
configuration:
retained: true
postCommand: false
transformationPatternOut: JSONPATH:$.state
stateTopic: zigbee2mqtt/0x7cb03eaa0a0b0edb
transformationPattern: JSONPATH:$.state
off: OFF
on: ON
I tried this to command the switch:
label: Switch(E003)
description: ""
configuration:
commandTopic: zigbee2mqtt/0x7cb03eaa0a0b0edb/set
postCommand: true
off: OFF
on: ON
I’m using the current firefox browser with “openhabian:8080” in the URL. I’m logged in as admin.
Kind regards,
Günther
