Environment:
VS Code Machine: Windows 10 Professional
OH Server: Windows Server 2012
Both are fully patched to latest updates
OH Version: 2.3 Build 1204
Whenever I open VS Code to do work on my OH setup I receive a popup error message stating that there is an internal error and I need to look at my server logs…
I look in my OH log file and find the following…any suggestions as I know many are using VS code and not running into this issue.
2018-05-15 20:20:45.085 [WARN ] [org.eclipse.jetty.io.ManagedSelector] -
java.lang.OutOfMemoryError: Java heap space
2018-05-15 20:20:45.103 [ERROR] [eclipse.lsp4j.jsonrpc.RemoteEndpoint] - Internal error: java.lang.reflect.InvocationTargetException
java.lang.RuntimeException: java.lang.reflect.InvocationTargetException
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:53) ~[102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.request(GenericEndpoint.java:105) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.handleRequest(RemoteEndpoint.java:203) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.consume(RemoteEndpoint.java:139) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.handleMessage(StreamMessageProducer.java:149) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:77) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at org.eclipse.lsp4j.jsonrpc.json.ConcurrentMessageProcessor.run(ConcurrentMessageProcessor.java:84) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
Caused by: java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.services.GenericEndpoint.lambda$null$0(GenericEndpoint.java:51) ~[?:?]
... 11 more
Caused by: java.lang.OutOfMemoryError: Java heap space
2018-05-15 20:20:45.096 [WARN ] [org.eclipse.jetty.io.ManagedSelector] -
2018-05-15 20:20:45.096 [ERROR] [org.apache.felix.fileinstall ] - In main loop, we have serious trouble
2018-05-15 20:20:45.147 [ERROR] [nrpc.json.ConcurrentMessageProcessor] - java.net.SocketException: Connection reset by peer: socket write error
java.lang.RuntimeException: java.net.SocketException: Connection reset by peer: socket write error
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageConsumer.consume(StreamMessageConsumer.java:68) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at org.eclipse.lsp4j.jsonrpc.RemoteEndpoint.handleRequest(RemoteEndpoint.java:208) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
Caused by: java.net.SocketException: Connection reset by peer: socket write error
at java.net.SocketOutputStream.socketWrite0(Native Method) ~[?:?]
at java.net.SocketOutputStream.socketWrite(SocketOutputStream.java:111) ~[?:?]
at java.net.SocketOutputStream.write(SocketOutputStream.java:143) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageConsumer.consume(StreamMessageConsumer.java:63) ~[?:?]
... 10 more
2018-05-15 20:20:45.514 [WARN ] [lipse.jetty.server.AbstractConnector] -
java.nio.channels.ClosedSelectorException: null
at sun.nio.ch.SelectorImpl.keys(SelectorImpl.java:68) [?:?]
at org.eclipse.jetty.io.ManagedSelector.size(ManagedSelector.java:104) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectorManager.chooseSelector(SelectorManager.java:190) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectorManager.accept(SelectorManager.java:232) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.io.SelectorManager.accept(SelectorManager.java:217) [79:org.eclipse.jetty.io:9.3.22.v20171030]
at org.eclipse.jetty.server.ServerConnector.accepted(ServerConnector.java:407) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.ServerConnector.accept(ServerConnector.java:398) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.server.AbstractConnector$Acceptor.run(AbstractConnector.java:601) [87:org.eclipse.jetty.server:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
2018-05-15 20:20:46.516 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:20:50.559 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:20:53.628 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:20:55.737 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:20:57.503 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:21:00.820 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:21:02.236 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:21:17.669 [ERROR] [eclipse.lsp4j.jsonrpc.RemoteEndpoint] - Internal error: java.lang.reflect.InvocationTargetException
... 11 more
2018-05-15 20:21:18.509 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:21:19.512 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:22:45.501 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:23:01.205 [ERROR] [nrpc.json.ConcurrentMessageProcessor] - java.net.SocketException: Connection reset
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:103) [102:org.eclipse.lsp4j.jsonrpc:0.2.1.v20170706-0855]
at java.net.SocketInputStream.read(SocketInputStream.java:210) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:?]
at java.net.SocketInputStream.read(SocketInputStream.java:224) ~[?:?]
at org.eclipse.lsp4j.jsonrpc.json.StreamMessageProducer.listen(StreamMessageProducer.java:61) ~[?:?]
... 6 more
2018-05-15 20:23:55.544 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:23:56.546 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:23:57.554 [ERROR] [g.jupnp.protocol.sync.ReceivingEvent] - Invalid subscription ID, no active subscription: (IncomingEventRequestMessage) NOTIFY /upnpcallback/dev/RINCON_000E582120FC01400_MR/svc/upnp-org/AVTransport/event/cb SEQUENCE: 0
2018-05-15 20:24:00.547 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:24:02.594 [ERROR] [g.jupnp.protocol.sync.ReceivingEvent] - Invalid subscription ID, no active subscription: (IncomingEventRequestMessage) NOTIFY /upnpcallback/dev/RINCON_000E582120FC01400_MR/svc/upnp-org/AVTransport/event/cb SEQUENCE: 0
2018-05-15 20:24:05.559 [WARN ] [lipse.jetty.server.AbstractConnector] -
2018-05-15 20:24:06.568 [ERROR] [g.jupnp.protocol.sync.ReceivingEvent] - Invalid subscription ID, no active subscription: (IncomingEventRequestMessage) NOTIFY /upnpcallback/dev/RINCON_000E5823AE2001400_MR/svc/upnp-org/AVTransport/event/cb SEQUENCE: 0
2018-05-15 20:24:10.568 [WARN ] [lipse.jetty.server.AbstractConnector] -
I also see error messages in the Karaf Console…
Any suggestions would be appreciated.
Squid
