Since I upgraded to openHAB 2.2.0-1 (Release Build), I have problems with myopenHAB Cloud Service and HTTP-Actions. My openHAB runs on a Raspberry Pi 3 Model B.
When I access the server with the Android app via remote URL, I suddenly have no connection to openHab. The log file contains the following message at this time:
2017-12-26 14:30:06.445 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 4729400 failed: null
2017-12-26 14:30:18.721 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 4729442 failed: null
2017-12-26 14:30:18.763 [WARN ] [io.openhabcloud.internal.CloudClient] - Jetty request 4729418 failed: null
After these error messages, the HTTP-Actions also no longer works. A rule that uses sendHttpGetRequest with the JSON transformation cyclically every 3 seconds produces the following message:
2017-12-26 14:30:21.491 [ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException
2017-12-26 14:30:21.506 [ERROR] [ore.transform.actions.Transformation] - Error executing the transformation 'JSONPATH': the given parameters 'JSonPath' and 'source' must not be null
2017-12-26 14:30:21.519 [ERROR] [ore.transform.actions.Transformation] - Error executing the transformation 'JSONPATH': the given parameters 'JSonPath' and 'source' must not be null
2017-12-26 14:30:24.456 [ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException
2017-12-26 14:30:24.471 [ERROR] [ore.transform.actions.Transformation] - Error executing the transformation 'JSONPATH': the given parameters 'JSonPath' and 'source' must not be null
2017-12-26 14:30:24.482 [ERROR] [ore.transform.actions.Transformation] - Error executing the transformation 'JSONPATH': the given parameters 'JSonPath' and 'source' must not be null
2017-12-26 14:30:27.491 [ERROR] [.smarthome.model.script.actions.HTTP] - Fatal transport error: java.util.concurrent.TimeoutException
2017-12-26 14:30:27.508 [ERROR] [ore.transform.actions.Transformation] - Error executing the transformation 'JSONPATH': the given parameters 'JSonPath' and 'source' must not be null
2017-12-26 14:30:27.516 [ERROR] [ore.transform.actions.Transformation] - Error executing the transformation 'JSONPATH': the given parameters 'JSonPath' and 'source' must not be null
After a certain amount of time this leads to this:
2017-12-26 14:32:41.180 [ERROR] [io.socket.thread.EventThread ] - Task threw exception
java.lang.OutOfMemoryError: Java heap space
at io.socket.engineio.parser.Parser.encodeByteArray(Parser.java:68) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.parser.Parser.encodePacket(Parser.java:51) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.parser.Parser.encodePacket(Parser.java:42) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.transports.WebSocket.write(WebSocket.java:184) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.Transport$3.run(Transport.java:108) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.thread.EventThread.exec(EventThread.java:55) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.Transport.send(Transport.java:103) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.Socket.flush(Socket.java:615) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.Socket.onDrain(Socket.java:606) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.Socket.access$1100(Socket.java:31) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.Socket$6.call(Socket.java:308) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.emitter.Emitter.emit(Emitter.java:117) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.engineio.client.transports.WebSocket$3$1.run(WebSocket.java:171) ~[219:org.openhab.io.openhabcloud:2.2.0]
at io.socket.thread.EventThread$2.run(EventThread.java:80) [219:org.openhab.io.openhabcloud:2.2.0]
2017-12-26 14:42:28.753 [WARN ] [ore.internal.events.OSGiEventManager] - Dispatching event to subscriber 'org.eclipse.smarthome.core.internal.items.ItemUpdater@23492a' takes more than 5000ms.
And a lot of these logs come after that:
2017-12-26 17:01:40.370 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /api/02a5f5ac-9760-4e5b-a2a5-411e9ae67d1d/lights
2017-12-26 17:01:58.334 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /api/02a5f5ac-9760-4e5b-a2a5-411e9ae67d1d/lights
2017-12-26 17:02:20.053 [WARN ] [eclipse.jetty.servlet.ServletHandler] - Error for /api/02a5f5ac-9760-4e5b-a2a5-411e9ae67d1d/lights
2017-12-26 17:07:58.884 [ERROR] [io.socket.thread.EventThread ] - Task threw exception
2017-12-26 17:08:15.274 [ERROR] [io.socket.thread.EventThread ] - Task threw exception
The myopenHAB Cloud Service will restart at some point, but the rule including ‘sendHttpGetRequest’ was stopped.
2017-12-26 17:33:59.407 [INFO ] [io.openhabcloud.internal.CloudClient] - Disconnected from the openHAB Cloud service (UUID = 1cadcc4d-5682-4160-a09f-fc71caf0d5ef, base URL = http://localhost:80)
2017-12-26 17:34:00.391 [WARN ] [e.jetty.util.thread.QueuedThreadPool] - HttpClient@2091292{STOPPING,8<=8<=200,i=0,q=1} Couldn't stop Thread[HttpClient@2091292-67908,5,]
2017-12-26 17:34:02.173 [INFO ] [io.openhabcloud.internal.CloudClient] - Connected to the openHAB Cloud service (UUID = 1cadcc4d-5682-4160-a09f-fc71caf0d5ef, base URL = http://localhost:80)
Does anyone have any idea what this might be? Under openHab 2.1 this worked fine. No changes have been made to the rules or settings since then.
