The problem I have is that the ELKO controller hardware seems to have a poor TCP stack implementation.
At least that is my guess, since the controller reboots frequently if it gets flooded with binding updates. The reboots dissapears if I add a delay between every consequtive sendCommands()
My question is if someone knows a way to create a new sendCommand() which basically is the old SendCommand() but with a thread::delay added.
I guess I am looking for a way of creating a function or redefining the sendCommand
Hi
Thank you for this answer
I must admit that I cannot see right now where I can find the sendCommand() function so I can modify it.
But maybe the way forward is to create a function “mysendCommand()” with Jython?
you can just override and inject the function as I have done (Thread here: Library for JSR223 in Jython).
But the easiest way is definitely to create a custom function:
def mysendCommand( a, b):
time.sleep(1)
BusEvent.sendCommand(a,b)
