Overview page does not show a widget, but other pages do
Hello everyone, I’m encountering an issue with openHAB 5.2.3 Main UI (running on openHABian):
I created a dashboard page that, among other things, fetches a snapshot from a ZoneMinder monitor and displays it within a widget. This works perfectly on the custom page I created. I then copied the entire code for this page and pasted it directly onto the “Overview” page. Everything displays without any issues while in edit mode or in the simulation; however, as soon as I log out or open the homepage in a new browser session, this specific widget fails to appear. Interestingly, if I navigate to my custom dashboard page (where the widget always displays correctly) and then return to the homepage, the widget suddenly appears as it should.
The reason I copied the code from the dashboard page to the Overview page is that I want this specific layout to be the first thing I see when starting a session. I haven’t found any other way to achieve this, as it seems there is no built-in option to set a page other than the “Overview” page as the homepage.
Is there a solution to this problem? Please let me know what additional information you might need (perhaps some code snippets?).
A much better approach would be to copy it and paste it into the Developer Tools → UI Widgets → + and set some properties if necessary. Then you can add that custom widget to both places by name instead of copying and pasting the code. See Pages - Custom Widgets | openHAB for details.
I suspect there is something that has gone wrong when copying and pasting the whole page. Something got messed up, a misaligned indentation or something like that. What I would do is build up the layout on the Overview page as you want it (rows, columns, etc.) and copy over the widgets individually, one by one. Even better I would create each widget as a custom widget instead of copy and paste. That makes the widgets independent units which makes future edits and manipulation much easier.
Beyond that, all I can recommend is posting the code for the ZoneMinder widget itself and someone better at UI widgets hopefully will be able to help, assuming the problem is with the widget instead of the layout.
Thanks for your reply! My dashboard page consists entirely of custom widgets; the code copied from the dashboard page actually works on the overview page as well—with one limitation: when the openHAB URL is first accessed, this particular widget displays no output. It only begins to work after the dashboard page has been visited (where the exact same widget functions correctly on the very first load) and one then immediately returns to the overview page. From that point on, everything works perfectly.
I have also checked the indentation; to me, everything looks correct.
There are a couple of different possibilities. Please show all the relevant yaml.
version: 1
pages:
  overview:
    tags: []
    props:
      parameters: []
      parameterGroups: []
    component: oh-layout-page
      label: Overview
      sidebar: false
      layoutType: fixed
      fixedType: canvas
      gridEnable: false
      screenWidth: 1920
      screenHeight: 1080
      hideNavbar: false
      hideSidebarIcon: false
      style:
        --f7-theme-color: "#64b5f6"
        --f7-page-bg-color: "#15191f"
        --f7-text-color: "#e5eaf0"
        --f7-label-text-color: "#cbd5df"
        --f7-input-text-color: "#e5eaf0"
        --f7-list-bg-color: "#252c34"
        --f7-list-item-border-color: "#414b56"
        --f7-card-bg-color: "#252c34"
        --f7-card-border-radius: 10px
        --f7-card-box-shadow: 0 3px 12px rgba(0,0,0,0.35)
        --f7-block-strong-bg-color: "#252c34"
        --f7-bars-bg-color: "#20262e"
        --f7-bars-text-color: "#e5eaf0"
        --f7-navbar-bg-color: "#20262e"
        --f7-navbar-text-color: "#e5eaf0"
        --f7-toolbar-bg-color: "#20262e"
        --f7-toolbar-text-color: "#e5eaf0"
        --f7-popup-bg-color: "#20262e"
        --f7-dialog-bg-color: "#252c34"
      pageStyle:
        background: "linear-gradient(145deg, #252c34 0%, #15191f 45%, #202832 100%)"
        color: "#e5eaf0"
      scale: false
      showFullscreenIcon: true
    slots:
      default: []
      masonry: []
      grid: []
      canvas:
        - component: oh-canvas-layer
            preload: true
          slots:
            default:
              - component: oh-canvas-item
                  x: 688
                  y: 29
                  h: 40
                  w: 125
                slots:
                  default:
                    - component: widget:anwesenheit_kachel
                        iconSize: 20
                  x: 20
                  y: 20
                  h: 70
                  w: 211
                slots:
                  default:
                    - component: widget:responsive_clock
                        fontSize: 14px
                  x: 19
                  y: 335
                  h: 254
                  w: 302
                slots:
                  default:
                    - component: widget:wettercom
                      config: {}
                  x: 19
                  y: 60
                  h: 271
                  w: 451
                  notStyled: true
                slots:
                  default:
                    - component: widget:zoneminder_snapshot
                        username: xxxxx
                        password: yyyyyyy
                        refreshSeconds: 15
                        baseUrl: http://192.168.5.18
                  x: 7
                  y: 823
                  h: 67
                  w: 204
                slots:
                  default:
                    - component: widget:location_jump_parameter_card_safe_color
                        locationItem: Pool
                        title: Pool
                        iconColor: blue
                  x: 203
                  y: 823
                  h: 68
                  w: 211
                slots:
                  default:
                        locationItem: Gartenteich
                        title: Teich
                        iconColor: blue
                  x: 317
                  y: 327
                  h: 44
                  w: 162
                slots:
                  default:
                    - component: widget:zoneminder_monitor
                        title: Terrasse
                        username: xxxxx
                        password: yyyyyyy
                        monitorId: "2"
                  x: 317
                  y: 398
                  h: 44
                  w: 162
                slots:
                  default:
                        monitorId: "3"
                        title: Stall
                        username: xxxxx
                        password: yyyyyyy
                  x: 475
                  y: 61
                  h: 253
                  w: 336
                slots:
                  default:
                    - component: widget:garbage_list_v0
                        footer: "='Nächster Termin: ' + ((dayjs(items.Muellkalender_Next_Start.state).diff(dayjs().startOf(\"day\"), \"days\")) == 0 ? \"Heute\" : (dayjs(items.Muellkalender_Next_Start.state).diff(dayjs().startOf(\"day\"), \"days\")) == 1 ? \"Morgen\" : \"In \" + (dayjs(items.Muellkalender_Next_Start.state).diff(dayjs().startOf(\"day\"), \"days\")) + \" Tagen\")"
                        tomorrow: morgen
                        today: heute
                        datearray: '"Restmüll","gray","f7:trash","Restmuell_Start"|"Biotonne","te000al","f7:trash","Biomuell_Start"|"Gelber Sack","yellow","f7:trash","Gelber_Sack_Start"|"Altpapier","red","f7:trash","Altpapier_Start"|"Problemstoffe","blue","f7:trash","Problemstoffe_Start"|"Rauchfangkehrer","black","pngegg.png","Rauchfangkehrer_Start"|"Deponie","gray","mull.png","Deponie_Start"'
                        title: Müllkalender
                  x: 475
                  y: 338
                  h: 251
                  w: 336
                slots:
                  default:
                    - component: widget:calendar_timeline_widget_upcoming
                        title: Familienkalender
                  x: 19
                  y: 610
                  h: 210
                  w: 455
                slots:
                  default:
                    - component: widget:dynamic-light-control
                        title: Lampen
                        lightGroup: gLampen
                  x: 477
                  y: 610
                  h: 210
                  w: 455
                slots:
                  default:
                    - component: widget:dynamic-switch-control
                        switchGroup: Group_Gartenverbraucher
                  x: 816
                  y: 61
                  h: 529
                  w: 571
                slots:
                  default:
                    - component: widget:fronius_energy_flow_v5_1
                        title: Stromflüsse
                        power_solar: Fronius_Symo_Inverter_Current_Solar_Yield
                        popup_solar: Fronius_Symo_Inverter_Current_Solar_Yield
                        power_battery: Fronius_Symo_Inverter_Charge__Discharge_of_Battery
                        popup_battery: Fronius_Symo_Inverter_Battery_State_of_Charge
                        soc_battery: Fronius_Symo_Inverter_Battery_State_of_Charge
                        power_inverter: Fronius_Symo_Inverter_Inverter_Power
                        popup_inverter: Fronius_Symo_Inverter_Inverter_Power
                        power_solar_max: 8000
                        power_grid: Fronius_Symo_Inverter_Grid_Power
                        popup_grid: Fronius_Symo_Inverter_Grid_Power
                        power_house: Fronius_Symo_Inverter_Load_Power
                        popup_house: Fronius_Symo_Inverter_Load_Power
                        use_dot_gradient: true
                  x: 936
                  y: 610
                  h: 210
                  w: 455
                slots:
                  default:
                    - component: widget:widget_power_consumption_analyzer
                        groupItem: Group_Power_Consumption
                  x: 403
                  y: 823
                  h: 75
                  w: 213
                slots:
                  default:
                        locationItem: ZWave_Node_003_MT02650_Devolo_Thermostat_09356
                        title: Heizung
                  x: 606
                  y: 825
                  h: 75
                  w: 213
                slots:
                  default:
                        locationItem: network
                        title: Netzwerk
                  x: 823
                  y: 22
                  h: 43
                  w: 200
                slots:
                  default:
                    - component: widget:compact_item_icon
                        item: Lokale_Sonnendaten_Sonnenaufgang_Sonnenaufgang
                        icon: oh:sunrise
                        layout: row
                        showState: true
                  x: 1192
                  y: 22
                  h: 43
                  w: 200
                slots:
                  default:
                        item: Lokale_Sonnendaten_Sonnenuntergang_Startzeit
                        icon: oh:sunset
                        layout: row
                  x: 453
                  y: 25
                  h: 38
                  w: 156
                slots:
                  default:
                        item: Jablotron_JA100_xxxx
                        iconSize: 20px
                        fontSize: 16px
                        icon: oh:alarm
                        layout: row
The widget not being displayes on initial page load is “widget:zoneminder_snapshot”
I’m going to guess that your zoneminder widget includes an oh-context component and some variables. If that’s the case, then this is a known bug.
There is a pull request in with a fix for this bug that, last I checked, was probably going to make it in before the 5.3 release at the end of the year. Unfortunately there’s not much you can do about it until then, it’s basically a problem with the ability of the oh-context to access items that haven’t been added to the UIs item state tracking yet.
Thnk you very much for your investigations!
Just to make sure, I attach the zoneminder widget code:
version: 1
widgets:
  zoneminder_snapshot:
    tags:
      - Kamera
    props:
      parameters:
        - default: http://voyeur.homedomain.local
          label: ZoneMinder Basis-URL
          required: true
          type: TEXT
        - default: "1"
          label: Monitor-ID
          required: true
          type: TEXT
        - label: Benutzername
          required: true
          type: TEXT
        - label: Passwort
          required: true
          type: TEXT
        - default: 5
          label: Snapshot-Intervall in Sekunden
          required: true
          type: INTEGER
      parameterGroups: []
    component: oh-image
      url: =props.baseUrl + "/zm/cgi-bin/nph-zms?mode=single&monitor=" + props.monitorId + "&scale=50&user=" + props.username + "&pass=" + props.password
      refreshInterval: =Number(props.refreshSeconds) * 1000
      lazy: false
      action: popup
      actionModal: widget:zoneminder_live_popup
      actionModalConfig: "=({baseUrl: props.baseUrl, monitorId: props.monitorId, username: props.username, password: props.password})"
      style:
        width: 100%
        height: auto
        cursor: pointer
        border-radius: 8px
For the time being, I can live with saving the functional dashboard page as a browser bookmark, allowing me to access it directly. Ultimately, however, the goal is to have it displayed in kiosk mode—though I’m not sure if that’s possible for a specific page. Just to meet the WAF (Wife Acceptance Factor).
Ok, your widget does not, in fact, have an oh-context so that is not the problem. There is something else going on here that just has similar symptoms.
Do you have the same issue if you set the canvas layer’s preload to false?
yes, the same issue, I’m afraid.
The strange thing about the whole situation is that the widget does not appear when the page is initially loaded; however, as soon as I (after logging in as an admin) go to edit the page and then exit the editing dialog—without having made any changes—by clicking “back,” the widget content is displayed.
I’ve run a few more tests and observed the following:
In the widget editor, a snapshot is displayed when the username/password combination is correct, while a “broken link” icon appears if the combination is incorrect—so far, so good.
On the overview page, however, the display remains empty when the username/password combination is correct, whereas a “broken link” icon appears if the combination is incorrect.
I’m going to check the ZoneMinder API logs for any errors.
Checked ZM error logs: As expected, ZoneMinder throws an error for the invalid user/password combinations only
Another check:
I entered an invalid username/password combination for the ZoneMinder widget on the overview page, then logged out and restarted the browser session. Once again, the widget area remains empty during the initial load—HOWEVER: if I click over to my functional custom dashboard page and then navigate back to the overview page, a “broken link” icon suddenly appears (which is actually the correct behavior). It seems there might be an issue with the initial loading process?
I agree, that’s why I asked about the preload setting.
Do you have to edit the page, or is just navigating to any other page and navigating back sufficient?
no, simple forward and back navigation is sufficient
One thing that still puzzles me a bit: is there a difference in how a custom page (like my dashboard page) loads compared to the standard overview page? I ask because accessing my dashboard page directly displays the widget output immediately.
Only because the overview page is a tabbed page, but that shouldn’t really impact the content any.
My guess is that it is not any difference between the two pages; it’s just that the second time the widget is loaded is always successful. That doesn’t matter if its 1 - Overview and 2 - Dashboard, or 1 - Overview and 2 - back to Overview.
To test that you could take the widget off the overview page and reload the UI (so we’re testing 1 - Dashboard and 2 - Dashboard). Then, if the issue is the widget handling itself and not the page handling, you will see the widget fail the first time you load the dashboard page, but navigating away and back to the dashboard will display the widget properly.
I’m not sure I understand you correctly: you want me to remove the widget from the overview page and then reload the UI? What am I testing by doing that? Sorry, I’m a bit lost here.
If I understand correctly, your widget is on two different pages: the overview and another dashboard page. I suspect that if the widget is not on your overview page that it will fail to load the first time you open the dashboard page because that will be the first time the UI processes the widget. If you reopen the dashboard page a second time it will work correctly.
If I have misunderstood and this widget only exists on the overview, then, to perform the same test, just create a quick test page with the widget on it and remove the widget from the overview page. The idea is to make sure that it is not anything special about the overview page that is causing the prolem.
Ah, okay – here’s the sequence of events:
New browser session → access http://openhab:8080 → overview page with empty widget output → navigate to a custom dashboard containing the same widget → navigate back to the overview page: the widget content is now displayed.
New browser session → access http://openhab:8080/page/page_ed204701e0 → the widget is displayed → navigate to the overview page: the widget is displayed.
In both cases, it is the same widget with exactly the same parameters. The code from the custom “dashboard” page was transferred to the “overview” page via copy-and-paste within the page editor.
I have now inserted the widget into a test page, and it displays without any issues.
Interestingly, I am now seeing the same behavior as with the dashboard page: when the overview page is loaded for the first time, the widget is empty; however, after visiting the test page and then navigating to the overview page, the widget content appears.
Well, at this point it certainly sounds like a bug and unless there are any errors in the browser console that tell us where to look when the widget fails to load, I don’t know what else to try and track down.
At this point, I suggest filing a bug report in the UI repository.
I figured as much :wink:
I’ll try to report a bug like this myself; in the past (in a former life), I used to let my guys handle that…
In any case, thank you very much for your help.
A timid question: in which repository—or for which repository—should I submit the issue on GitHub? There are several UI respositories
It can get a little overwhelming. This is not specific to a certain mobile interface, but seems to be an issue with MainUI itself. MainUI and the other historically official UIs (basicUI etc.) are all under the single webui repo:
You should file the issue there and just make sure you select the MainUI bug report template.
