- Platform information:
- Hardware: Synology: DS918+
- OS: Synology: DSM 7.1.1-42962 Update 6 / Docker
- Java Runtime Environment: irrelevant as I use docker with latest openhab 4.1
- openHAB version: 4.1
- Issue of the topic: I get a “unknown API error (-1)” upon creating thing P110 (cloud bridget setup correctly and working)
- Please post configurations (if applicable):
This is a completely new setup of openhab 4.1 on my synology docker as currently all attempts of migration from 3.2. to 4.1 failed (see other topic here: Upgrade from 3.2 to 4.1 -> web requests from local network to 8080 are denied - #34 by hheckner - Migration - openHAB Community
I setup successfully the tapo binding:
I successfully added all 3 P110 devices via cloud discovery.
My assumption is that I recently did a firmware upgrade of the P110 to Version 1.2.3 Build 230425 Rel. 142542
and this causes the API problem
Why I am thinking this?
Because I had one P110 not yet upgraded and then the error was different:
After hitting save it said that for the given MAC adress of this very device I need to check the IP adress (which was obviously correct as I had it copied from the TAPO App on my iphone). After doing the firmware update (via TAPO App on Iphone) the same error unknown API -1 was returned for this device.
- If logs where generated please post these here using code fences:
events.log: (extract)
2023-12-29 08:43:05.797 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:c8d1653801' changed from UNKNOWN: unknown api error (-1) to OFFLINE (COMMUNICATION_ERROR): unknown api error (-1)
2023-12-29 08:43:35.808 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:c8d1653801' changed from OFFLINE (COMMUNICATION_ERROR): unknown api error (-1) to UNKNOWN: unknown api error (-1)
2023-12-29 08:43:35.809 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:c8d1653801' changed from UNKNOWN: unknown api error (-1) to OFFLINE (COMMUNICATION_ERROR): unknown api error (-1)
2023-12-29 08:44:05.819 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:c8d1653801' changed from OFFLINE (COMMUNICATION_ERROR): unknown api error (-1) to UNKNOWN: unknown api error (-1)
2023-12-29 08:44:05.821 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'tapocontrol:P110:c8d1653801' changed from UNKNOWN: unknown api error (-1) to OFFLINE
openhab.log:
2023-12-29 08:06:05.771 [WARN ] [ntext.named.DiscriminatingNameMapper] - Failed to get hostname, using 'localhost'
java.net.UnknownHostException: oh: oh: Name or service not known
at java.net.InetAddress.getLocalHost(InetAddress.java:1671) ~[?:?]
at shaded.org.eclipse.aether.internal.impl.synccontext.named.DiscriminatingNameMapper.getHostname(DiscriminatingNameMapper.java:100) [bundleFile:?]
at shaded.org.eclipse.aether.internal.impl.synccontext.named.DiscriminatingNameMapper.<init>(DiscriminatingNameMapper.java:83) [bundleFile:?]
at shaded.org.eclipse.aether.internal.impl.synccontext.named.SimpleNamedLockFactorySelector.<clinit>(SimpleNamedLockFactorySelector.java:60) [bundleFile:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:77) [?:?]
at jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) [?:?]
at java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:499) [?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:480) [?:?]
at shaded.org.eclipse.aether.impl.DefaultServiceLocator$Entry.newInstance(DefaultServiceLocator.java:176) [bundleFile:?]
at shaded.org.eclipse.aether.impl.DefaultServiceLocator$Entry.getInstances(DefaultServiceLocator.java:151) [bundleFile:?]
at shaded.org.eclipse.aether.impl.DefaultServiceLocator$Entry.getInstance(DefaultServiceLocator.java:137) [bundleFile:?]
at shaded.org.eclipse.aether.impl.DefaultServiceLocator.getService(DefaultServiceLocator.java:296) [bundleFile:?]
at shaded.org.eclipse.aether.internal.impl.synccontext.DefaultSyncContextFactory.initService(DefaultSyncContextFactory.java:70) [bundleFile:?]
at shaded.org.eclipse.aether.impl.DefaultServiceLocator$Entry.newInstance(DefaultServiceLocator.java:181) [bundleFile:?]
at shaded.org.eclipse.aether.internal.impl.DefaultMetadataResolver.initService(DefaultMetadataResolver.java:124) [bundleFile:?]
at shaded.org.apache.maven.repository.internal.DefaultVersionResolver.initService(DefaultVersionResolver.java:108) [bundleFile:?]
at shaded.org.eclipse.aether.internal.impl.DefaultRepositorySystem.initService(DefaultRepositorySystem.java:145) [bundleFile:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.newRepositorySystem(AetherBasedResolver.java:1232) [bundleFile:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.<init>(AetherBasedResolver.java:171) [bundleFile:?]
at org.ops4j.pax.url.mvn.internal.AetherBasedResolver.<init>(AetherBasedResolver.java:158) [bundleFile:?]
at org.ops4j.pax.url.mvn.internal.Activator.updated(Activator.java:182) [bundleFile:?]
at org.ops4j.pax.url.mvn.internal.Activator$OptionalConfigAdminHelper$1.updated(Activator.java:271) [bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189) [bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152) [bundleFile:?]
at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$UpdateConfiguration.run(ConfigurationManager.java:1418) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:122) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:84) [bundleFile:?]
Caused by: java.net.UnknownHostException: oh: Name or service not known
at java.net.Inet6AddressImpl.lookupAllHostAddr(Native Method) ~[?:?]
at java.net.InetAddress$PlatformNameService.lookupAllHostAddr(InetAddress.java:934) ~[?:?]
at java.net.InetAddress.getAddressesFromNameService(InetAddress.java:1543) ~[?:?]
at java.net.InetAddress$NameServiceAddresses.get(InetAddress.java:852) ~[?:?]
at java.net.InetAddress.getAllByName0(InetAddress.java:1533) ~[?:?]
at java.net.InetAddress.getLocalHost(InetAddress.java:1666) ~[?:?]
... 44 more
2023-12-29 08:06:32.685 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.1.0 (build Release Build)
2023-12-29 08:06:40.268 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 172.17.0.1
2023-12-29 08:06:40.269 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 192.168.178.32
2023-12-29 08:06:41.767 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2023-12-29 08:06:51.875 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2023-12-29 08:07:29.575 [WARN ] [.io.rest.auth.internal.TokenResource] - Couldn't find a user with a session matching the provided refresh_token
2023-12-29 08:07:29.577 [WARN ] [.io.rest.auth.internal.TokenResource] - Token issuing failed: invalid_grant
2023-12-29 08:09:27.364 [INFO ] [p.auth.internal.AuthorizePageServlet] - First user account created: openhab
2023-12-29 08:09:45.019 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2023-12-29 08:09:45.020 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2023-12-29 08:11:12.610 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '48.11299733852165,11.627633571624756'.
2023-12-29 08:13:06.479 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'avmfritz:fritzbox:192_168_178_1' to inbox.
2023-12-29 08:13:25.939 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager gestartet und erreichbar unter http(s)://172.21.0.1:8080/shelly/manager
2023-12-29 08:13:33.980 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://192.168.178.32:8080/rest/addons/binding-upnpcontrol's Observer
2023-12-29 08:13:35.053 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2023-12-29 08:13:35.980 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://192.168.178.32:8080/rest/addons/binding-upnpcontrol's Observer
2023-12-29 08:14:37.991 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://192.168.178.32:8080/rest/addons/binding-upnpcontrol's Observer
2023-12-29 08:14:38.333 [WARN ] [service.internal.HttpServiceDisabled] - Http service has already been stopped
2023-12-29 08:14:38.949 [INFO ] [org.openhab.core.Activator ] - Starting openHAB 4.1.0 (build Release Build)
2023-12-29 08:14:39.108 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Time zone set to 'Europe/Berlin'.
2023-12-29 08:14:39.120 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Location set to '48.11299733852165,11.627633571624756'.
2023-12-29 08:14:39.121 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to 'de_DE'.
2023-12-29 08:14:39.989 [WARN ] [.transport.servlet.ServletController] - Can't find the request for http://192.168.178.32:8080/rest/addons/binding-upnpcontrol's Observer
2023-12-29 08:14:41.372 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 172.17.0.1
2023-12-29 08:14:41.373 [WARN ] [org.openhab.core.net.NetUtil ] - Found multiple local interfaces - ignoring 192.168.178.32
2023-12-29 08:14:44.529 [INFO ] [.core.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2023-12-29 08:14:48.363 [INFO ] [nternal.manager.ShellyManagerServlet] - Shelly Manager gestartet und erreichbar unter http(s)://172.21.0.1:8080/shelly/manager
2023-12-29 08:14:48.375 [WARN ] [core.karaf.internal.FeatureInstaller] - Could not determine addons folder, its content or the list of installed repositories!
2023-12-29 08:14:48.377 [INFO ] [core.karaf.internal.FeatureInstaller] - Some .kar files are not installed yet. Delaying add-on installation by 15s.
2023-12-29 08:14:54.407 [INFO ] [e.automation.internal.RuleEngineImpl] - Rule engine started.
2023-12-29 08:15:00.379 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'upnpcontrol:upnpserver:00113297-ede6-0011-e6ed-e6ed97321100' to inbox.
2023-12-29 08:22:04.111 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'shelly:shellyplusplug:64b7080c918c' to inbox.
2023-12-29 08:22:34.291 [INFO ] [y.internal.handler.ShellyBaseHandler] - shellyplusplugs-64b7080c918c: INFO: Neue Firmware verfügbar: aktuelle Version: 0.13.0-, neue Version: 1.1.0
2023-12-29 08:28:23.912 [WARN ] [l.internal.handler.UpnpServerHandler] - Cannot serve media from server heckner_storage, no renderer selected
2023-12-29 08:29:07.576 [WARN ] [uth.internal.AbstractAuthPageServlet] - Authentication failed from 192.168.178.105: Wrong password for user openhab
2023-12-29 08:29:15.463 [WARN ] [uth.internal.AbstractAuthPageServlet] - Authentication failed from 192.168.178.105: Wrong password for user openhab
2023-12-29 08:52:40.087 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tapocontrol:P110:012b617b73:54AF977CC72F' to inbox.
2023-12-29 08:52:40.091 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tapocontrol:P110:012b617b73:54AF977CBAB8' to inbox.
2023-12-29 08:52:40.095 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing 'tapocontrol:P110:012b617b73:54AF977CB69A' to inbox.
audit.log is empty.
