I have an openhab 3 instance running with the zigbee ember controller as my zigbee binding. I have a number of different things already connected and working, but lately I bought a few Aqara Motion Sensor P1’s because I needed some motion sensors with built in light in them. https://www.aqara.com/en/product/motion-sensor-p1
The problem I am running into is that the sensor pairs (Under a wierd name LUMI lumi.motion.ac02) but the only channel it presents is the Battery Voltage channel, which is helpful, granted, but it is not exactly the most important one.
I have been keeping an eye on the event log, and even though the device is listed as online, and that is reflected in the log, I have seen no channel events from it at all.
Is there something I am missing? Does anyone have the sensor working using the zigbee binding? And if so, is there some way to just manually configure the damn thing so it will work?
Openhab’s zigbee binding might not have supported it yet. If you could provide the zigbee fingerprint as @Ap15e mentioned above, it may be added into the binding in the future.
I don’t use the zigbee binding, but instead I’m using zigbee2mqtt to connect my zigbee stuff with openhab.
It depends whether you just want it to work right now, or you’d like to help the built in binding to expand its support.
I’ll get the fingerprint output as soon as possible. If you guys know where to look in the code I am probably not ready to do a PR at this point but I would love to have a look
