- Platform information:
- desktop PC, fast CPU, 64GB ram
- OS: windows 10
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 2.5.3
- Issue of the topic:
The android setup and control program for the Logitech Harmony lets one to add Hue devices. I have a TP-link dimmer configured in OH that I’m trying to make available through the Hue emulation service to the harmony hub and remote.
I have gotten to the point where the Harmony app discovers the OH Hue emulation service and am being asked by the app to press the center button on the Hue bridge device. I obviously don’t have such a device or button to press.
I’ve tried toggling the “Device Pairing” switch to “on” in the Hue Emulation configuration page, but the app doesn’t detect the emulated hub.
I’ve been using this page to get things working to this point.
I have added “set OPENHAB_HTTP_PORT=80” to start.bat. Prior to doing this, the app didn’t detect the emulated hue bridge, probably because OH was running on port 8080.
I opened the firewall for incoming port 1900/udp connections.
I expect to run into other problems as the documentation (above) has several methods for configuring the item I want to expose, including setting tags, but I don’t see any tags in the item’s configuration page in PaperUI. Also, the Category was set to DimmableSwitch (I think), not Switch or Dimmer as required by the doc, and a bunch of new things have been discovered (CLIP Generic …" since I added the Hue emulator service.
Anyways, trying to get past this one hurdle right now.
- Please post configurations (if applicable):
- Items configuration related to the issue
Configuration file: D/openhab-2.5.3/userdata/config/org/openhab/hueemulation.config
:org.apache.felix.configadmin.revision:=L"12" createNewUserOnEveryEndpoint=B"false" discoveryIp="10.0.0.4" ignoreItemsWithTags="internal" pairingEnabled=B"false" pairingTimeout="60" permanentV1bridge=B"false" restrictToTagsColorLights="ColorLighting" restrictToTagsSwitches="Switchable" restrictToTagsWhiteLights="Lighting" service.pid="org.openhab.hueemulation" temporarilyEmulateV1bridge=B"false" uuid="028fe059-db90-4df4-bbea-aa52e0d1d3a7"
Response from http://localhost:80/description.xml:
1
0http://[fe80:0:0:0:69ff:9b12:a368:f5e4]:80/
urn:schemas-upnp-org:device:Basic:1 openHAB Hue Emulation ([fe80:0:0:0:69ff:9b12:a368:f5e4]) Royal Philips Electronics http://www.openhab.org Philips hue Personal Wireless Lighting Philips hue bridge 2015 BSB002 http://www.meethue.com 028FE059DB90 uuid:028fe059-db90-4df4-bbea-aa52e0d1d3a7 openHAB index.html image/png 48 48 24 hue_logo_0.png image/png 120 120 24 hue_logo_3.png
Any assistance will be appreciated!
Thanks,
- Eric
