Where do I find/fetch the new release from?
See first post, files are updated in-place.
looked at that before, wasn´t sure if the referred file is the latest judging by the file name.
Thanks for clarifying
Hey Arne,
thanks for your endless effords on this binding!
PM me pls for a super thanks option
While the login got fixed, the polling was too agressive after all and requests were rejected causing things to transition between offline and online.
Hopefully the latest version passes the rate limit gatekeeper.
Jar files updated.
Hey Arne, I have a couple of those: CZ-KPY4 (cassettes). I get “Could not find device in internal model, check deviceId configuration”. Perhabs I could add it to the model myself if you provide a hint where and how to do it (didn’t check the code yet, to be honest)?
If you can find them in the PCC app, they should be found in the binding as well (disclaimer: PCC APIs change without notice nor changelog, all is reverse engineering).
Did you try to autodiscover them?
BRG
They are working in the App. Yes, Autodiscover didn’t find them. But this also didn’t work for the other wall mounted ones where I have already 3 added (manually with model + serial) and working via your binding.
The Cassette do not have Wifi native. I had to connect a (Panasonic) Wifi module to them. I don’t know if that makes a difference. Adding them in the PCC App worked the same way without issues.
BR
Try setting log level to DEBUG and send me the logs via PM. I’ll take a look.
Just to let you know, if anyone else has login issues, I solved mine by using Appversion: 2.1.0
Thanks @seime for the excellent work
Thanks for reporting @martin1338 , I’ve updated the default version in the addon and published.
