No,
You need to create an items file: eg. myitems.items in the items folder of your conf directory
and inside the file write my example above only replace mySwitch with the name of your item that you can get from the paper UI
Once you start working with the items files you will find that it is much more powerful that the UI
Some years back, but still the same question for me. I normally work with item-files, except a Jeelink Sensor topic is handled via GUI. Does a way exist today at v4.1 to add Expire @GUI level…
