I setup Openhab on my RPI3 mith myopenhab. The connection runs fine, but if I want to change s.th. I always get
"ERROR: 404 OK"
I have a slow upload on my DSL-Connection. Maybe this can cause the problem?
If I access PaperUI local or even through VPN than it runs fine and the error does not show up
Any experience with this problem?
Hello I always log into myopenhab and then click on PaperUI.
Everything shows up and works fine until I want to change s. th. I cannot rename a Thing or Item. The Error 404 shows up and the Thing has the same name than before. I cant install e. g. new bindings.
