i use the network binding and store online state to influxdb.
I tried to chart the online state in habmin, i does not work it says NaN. How do i apply a transformation rule to the items ?
thanks in advance
Lars
thanks in advance
Lars
the item is automatically created by network bindung, visible in paperui. the items also autogenerated an the tooling to configuration is the paperui. in good ald plain .item file, the configuration for transformation is done in the item file… (binding). i would expect that i may change the transformation in the item definition in paperui isn´t ? so just ask or describe why you changed the the titel of my issue!
