Paradox Binding & Paper UI
I’m a brand new user and trying to use the Paper UI to configure the Paradox EVO binding.
When creating items from the discovered channels I see the following errors in the logs:
Received HTTP PUT request at ‘items/ZoneOfficePIR_ZoneState’ with an invalid item type ‘contact’.
Received HTTP PUT request at ‘items/ZoneOfficePIR_Tampered’ with an invalid item type ‘switch’.
I assume this is a case sensitivity issue as the types are supposed to the ‘Contact’ and ‘Switch’? Where do I find the discovery ‘templates’ on the file system to fix this?
I assume that is in the binding so I added that tag too.
