Thanks in advance for the help, sorry if this is a noob post.
- Platform information:
- Hardware: Virtual; 4c / 8GB
- OS: Win10 1909
- Java Runtime Environment: JRE v8 build 231
- openHAB version: 2.4
SETUP: For almost a year, I have been pulling my Awair’s air sensor data from their API via the http1 binding and parsing it with JSONPATH (works great for the most part!). A sample below:
Awair.items:
String Stat_Awair_Temp_json “Stat_Awair_Temp_json [%s]” {http=“<[AwairCache:288000:JSONPATH($.data[0].sensors[0].value)]”}
Number Stat_Awair_Temp “Stat_Awair_Temp [%d °F]” (Group_Awair)
Awair_Temperature.rules:
rule “Convert Awair_Temp JSON to Item Type Number”
Item Stat_Awair_Temp_json changed
// use the transformation service to retrieve the value
val newValue = transform(“JSONPATH”, “$.data[0].sensors[0].value”, Stat_Awair_Temp_json.state.toString)
// post the new value to the Number Item
Stat_Awair_Temp.postUpdate( newValue )
The problem is that the API doesn’t always return the sensors[#] the same, so sometimes I end up with humidity or CO2 data where my temperature data should be. Awair support suggested that I try parsing the returned data with JS instead of JSONPATH. Here’s what I’m trying to do now:
Awair.items:
String TESTTEMP “TESTTEMP [%s]” { http=“<[AwairCache:288000:JS(GetTemp.js)]” }
Number TESTTEMPNUM “TESTTEMPNUM [%d °F]”
GetTemp.js:
(function(i) {
var sensors = i.data[0].sensors;
for (var sensor in sensors) {
if (sensors[sensor].comp == “temp”) {
return sensors[sensor].value;
})(input)
I’ve separately verified the ‘GetTemp.js’ code is good, as when I replace ‘input’ with the raw JSON the API gives, it parses no problem and returns the temperature value. However, when trying to run this in OHAB, it throws this error:
2020-07-10 13:19:25.184 [WARN ] [ab.binding.http.internal.HttpBinding] - Transformation ‘JS(GetTemp.js)’ threw an exception. [response={“data”:[{“timestamp”:“2020-07-10T18:19:15.000Z”,“score”:80.0,“sensors”:[{“comp”:“temp”,“value”:81.68000068664551},{“comp”:“humid”,“value”:57.36000061035156},{“comp”:“co2”,“value”:660.0},{“comp”:“voc”,“value”:411.0}],“indices”:[{“comp”:“temp”,“value”:1.0},{“comp”:“humid”,“value”:1.0},{“comp”:“co2”,“value”:0.0},{“comp”:“voc”,“value”:1.0}]}]}]
org.openhab.core.transform.TransformationException: An error occurred while executing script.
at org.openhab.core.transform.TransformationHelper$TransformationServiceDelegate.transform(TransformationHelper.java:67) ~[214:org.openhab.core.compat1x:2.4.0]
at org.openhab.binding.http.internal.HttpBinding.execute(HttpBinding.java:194) [212:org.openhab.binding.http:1.13.0]
at org.openhab.core.binding.AbstractActiveBinding$BindingActiveService.execute(AbstractActiveBinding.java:144) [214:org.openhab.core.compat1x:2.4.0]
at org.openhab.core.service.AbstractActiveService$RefreshThread.run(AbstractActiveService.java:166) [214:org.openhab.core.compat1x:2.4.0]
I’m sure I’ve just not configured something correctly; any help anyone can give is much appreciated!
