Hello everyone!
I use the rules https://community.openhab.org/t/i-o-module-bit-masks/102513/63?u=noobastik these are the rules to control my input and output modules. I need to wait for one ithem (ON OFF) to be executed and only then perform the next change in another Ithem (ON OFF).
JavaScript would work better here with array. But this should be a good start.
var java.util.ArrayList<Boolean> lightStates = newArrayList(false, false, false) // Initialize to 'false' for each light so add as many false as your number of lights very important
var Boolean isProcessing = false
rule "Device in"
Item InOut changed
var BigInteger register = (InOut.state as DecimalType).toBigDecimal.toBigInteger
gLights.members.forEach[i |
val Integer nBit = Integer::parseInt(i.name.split("_").get(1)) - 1
val Boolean targetState = register.testBit(nBit)
i.postUpdate(if(targetState) ON else OFF)
lightStates.set(nBit, targetState)
rule "Device out"
Member of gLights received command
if (!isProcessing) {
isProcessing = true
val Integer nBit = Integer::parseInt(triggeringItem.name.split("_").get(1)) - 1
if(receivedCommand == ON) {
register = register.setBit(nBit)
} else {
register = register.clearBit(nBit)
InOut.sendCommand(register)
rule "Sequential Execution"
Member of gLights changed
isProcessing = true
for (var i = 0; i < lightStates.size; i++) {
val light = gLights.members.findFirst[name | name.endsWith("_" + (i + 1).toString)]
if (light !== null) {
val targetState = lightStates.get(i)
if ((light.state == ON && !targetState) || (light.state == OFF && targetState)) {
light.postUpdate(if(targetState) ON else OFF)
Hmm… I was thinking of adding a pause I’ll try to figure out the code, thanks for the help!
Instead a pause / wait use a timer to schedule your code and run it later.
There are several examples if you try the search function
How many Items are we talking about here?
If it’s just two, trigger another rule to run once the first Item changes to perform the next task.
If it’s more than two, there’s Thread.sleep() or Timers.
Two I/O modules with 25 connections each.
