xoxys
(Robert)
September 26, 2018, 11:31am
#1
Platform information:
Hardware: Raspnerry Pi 2
OS: CentOS 7
Java Runtime Environment: zulu latest
openHAB version: 2.3.0
i have some performance issues with nginx in front of openhab 2. The load time from openhab without nginx is round about a second but if i open the webinterface over nginx there is a very high load time from more than 5 seconds before the webinterface is accessable…
The nginx is running on a separate server and used as proxy for multiple applications. No one of the other apps (e. g. Ubiquiti Unifi Controller, also a Java application) behind this proxy has these issues, so i have no idea what’s causing the problems with openhab…
Has anyone noticed similar behavior?
Benjy
(Ben Clark)
September 26, 2018, 11:36am
#2
Could we see your nginx configuration? I’m assuming it’s similar to the one suggested .
xoxys
(Robert)
September 26, 2018, 11:59am
#3
Yes, vhost server block is the same as mentioned in the docs with (i think so ) not necessary differents:
use nginx upstrean instead of direct proxy pass
upstream backend {
server 1.2.3.4:8443;
server {
listen 80;
server_name myserver.example.com ;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl;
location / {
proxy_pass https://backend;
proxy_set_header Host $host;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
ssl_certificate /etc/pki/tls/certs/mycert;
ssl_certificate_key /etc/pki/tls/private/mykey;
ssl_ciphers ‘ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-SHA’;
ssl_prefer_server_ciphers on;
ssl_protocols TLSv1.2;
ssl_session_cache shared:SSL:10m;
add_header Strict-Transport-Security “nginx_hsts_max_age=63072000; includeSubDomains”;
add_header X-Frame-Options DENY;
add_header X-Content-Type-Options nosniff;
add_header X-XSS-Protection “1; mode=block”;
and basic gzip compression setting in nginx.conf
Benjy
(Ben Clark)
September 26, 2018, 12:36pm
#4
I’m not sure unfortunately.
What is taking the largest amount of time when you look at the performance metrics (inside chrome or firefox) and refreshing the page?
xoxys
(Robert)
September 26, 2018, 12:44pm
#5
I can’t say at the moment but will have a look at home
xoxys
(Robert)
September 26, 2018, 8:22pm
#6
Ok, i found the “issue”… so what i figured out:
browser — https —> nginx — https —> openhab
endless slow… chrome says 5s
browser — https —> nginx — http —> openhab
works good, < 1s
browser — https —> openhab
works good, < 1s
I have no idea whats going on and why nginx with ssl passthrough to openhab is so slow… Any suggestions?
xoxys
(Robert)
October 6, 2018, 12:53am
#7
@Benjy can you reproduce this behaviour? Should we open an issue for this?
Benjy
(Ben Clark)
October 7, 2018, 1:14pm
#8
I won’t be able to for a couple of days, but will try and let you know what I find soon.
xoxys
(Robert)
October 29, 2018, 7:53am
#9
@Benjy any news? Otherwise i can also open an issue.
