Hi Sebastian,
I’m runnig Version 1.04.
Actually I have some effects in the logfiles, that I could not explanin,
or I did not know how to debug that.
For example:
I have some blind-controls that were controlled over the FritzBox.
Even if the blinds were not moving I get permanetly messages in the habapp event log.
The openhab log is quiet.
Any ideas how to debug it, cause it is flooding my logs.
Here is a example:
That’s from the eventlog
[2022-10-23 20:15:30,087] [ HABApp.EventBus] INFO | TsPhone: <ItemStateEvent name: TsPhone, value: ON>
[2022-10-23 20:16:30,132] [ HABApp.EventBus] INFO | TsPhone: <ItemStateEvent name: TsPhone, value: ON>
[2022-10-23 20:16:09,184] [ HABApp.EventBus] INFO | avmfritz:HAN_FUN_BLINDS:192_168_178_1:142760503249_1: <ThingStatusInfoEvent name: avmfritz:HAN_FUN_BLINDS:192_168_178_1:142760503249_1, status: ONLINE, detail: None>
[2022-10-23 20:16:39,193] [ HABApp.EventBus] INFO | avmfritz:HAN_FUN_BLINDS:192_168_178_1:142760530388_1: <ThingStatusInfoEvent name: avmfritz:HAN_FUN_BLINDS:192_168_178_1:142760530388_1, status: ONLINE, detail: None>
[2022-10-23 20:16:09,177] [ HABApp.EventBus] INFO | SZBL_Rollladensteuerung: <ItemStateEvent name: SZBL_Rollladensteuerung, value: 45.0%>
[2022-10-23 20:16:24,190] [ HABApp.EventBus] INFO | SZBL_Rollladensteuerung: <ItemStateEvent name: SZBL_Rollladensteuerung, value: 45.0%>
[2022-10-23 20:16:54,194] [ HABApp.EventBus] INFO | SZBL_Rollladensteuerung: <ItemStateEvent name: SZBL_Rollladensteuerung, value: 45.0%>
[2022-10-23 20:16:24,202] [ HABApp.EventBus] INFO | AZBL_Rollladensteuerung1: <ItemStateEvent name: AZBL_Rollladensteuerung1, value: 100.0%>
[2022-10-23 20:16:39,213] [ HABApp.EventBus] INFO | AZBL_Rollladensteuerung1: <ItemStateEvent name: AZBL_Rollladensteuerung1, value: 100.0%>
[2022-10-23 20:16:54,206] [ HABApp.EventBus] INFO | AZBL_Rollladensteuerung1: <ItemStateEvent name: AZBL_Rollladensteuerung1, value: 100.0%>
In the same time, no entries in the openhab log
022-10-23 20:08:08.784 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AZTH_Externaltemperature1' changed from 19.06 to 19.03
2022-10-23 20:08:08.793 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AZAQT_Temperature' changed from 19.06 to 19.03
2022-10-23 20:08:08.805 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AZAQT_AZAQQTemperature' changed from 19.06 °C to 19.03 °C
2022-10-23 20:08:08.807 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AZAQT_Pressure' changed from 67.01 to 67.24
2022-10-23 20:08:08.809 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AZAQT_Humidity' changed from 67.01 to 67.24
2022-10-23 20:15:18.559 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZAQT_Temperature' changed from 19.73 to 19.7
2022-10-23 20:15:18.570 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZAQT_Humidity' changed from 66.42 to 66.78
2022-10-23 20:15:18.573 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZAQT_Pressure' changed from 1003.1 to 1003.4
2022-10-23 20:16:00.002 [INFO ] [openhab.event.ChannelTriggeredEvent ] - astro:sun:local:night#event triggered START
2022-10-23 20:16:00.005 [INFO ] [openhab.event.ChannelTriggeredEvent ] - astro:sun:local:eveningNight#event triggered START
2022-10-23 20:16:00.008 [INFO ] [openhab.event.ChannelTriggeredEvent ] - astro:sun:local:astroDusk#event triggered END
2022-10-23 20:17:29.715 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KUNA_CO2Gehalt' changed from 451 ppm to 452 ppm
2022-10-23 20:17:29.732 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'KUNA_Batterieladung' changed from 62 to 63
2022-10-23 20:17:29.761 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SZNA_CO2Gehalt' changed from 600 ppm to 598 ppm
2022-10-23 20:17:29.775 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'SZNA_Batterieladung' changed from 26 to 30
2022-10-23 20:17:29.789 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RANA_KumulierterNiederschlag1h' changed from 1.5 mm to 1.2 mm
2022-10-23 20:17:29.797 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'RANA_MeasuresTimestamp' changed from 2022-10-23T20:06:49.000+0200 to 2022-10-23T20:16:52.000+0200
2022-10-23 20:17:29.812 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'AZNA_CO2Gehalt' changed from 431 ppm to 416 ppm
2022-10-23 20:17:29.835 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'OSNA_Temperatur' changed from 17.1 °C to 16.9 °C
2022-10-23 20:17:29.871 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZNA_MeasuresTimestamp' changed from 2022-10-23T20:07:24.277534+0200 to 2022-10-23T20:17:29.784224+0200
2022-10-23 20:17:29.873 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZNA_CO2Gehalt' changed from 401 ppm to 416 ppm
2022-10-23 20:19:10.173 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZAQT_Temperature' changed from 19.7 to 19.71
2022-10-23 20:19:10.194 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZAQT_Humidity' changed from 66.78 to 66.64
2022-10-23 20:19:10.200 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'WZAQT_Pressure' changed from 1003.4 to 1003.2
So do you have any ideas?
