- Platform information:
- Hardware: Raspberry Pi 4 2GB RAM with 16 GB SD card
- OS: Openhabian 3.0.1 - Release Build
- Java Runtime Environment: Zulu11.45+27-CA (build 11.0.10+9-LTS)
- openHAB version: 3
still very much a beginner… trying to read as much as possible and follow advice elsewhere before posting for help.
My error looks a lot like the one described at
But, in my case, the relevant directory wasn’t empty.
Posting what I think is the relevant part of the terminal output. It may be completely irrelevant but the output also seems to be telling me that I’m using a default password but I’ve changed all 4 of them (and checked each one apart from Amanda which I haven’t set up yet).
$ fix_permissions /opt/zram/log.bind/openhab openhab:openhabian 664 775
+ fix_permissions /opt/zram/log.bind/openhab openhab:openhabian 664 775
+ [[ -e /opt/zram/log.bind/openhab ]]
+ chown openhab:openhabian /opt/zram/log.bind/openhab
+ [[ -n 664 ]]
+ [[ -f /opt/zram/log.bind/openhab ]]
+ [[ -n 775 ]]
+ [[ -d /opt/zram/log.bind/openhab ]]
+ find /opt/zram/log.bind/openhab -type d -print0
+ xargs -0 chmod 775
+ return 0
+ echo 'FAILED (openhab log on zram)'
+ retval=1
+ [[ -d /etc/homegear ]]
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "10 | Apply Improvements"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
+ return 0
+ true
+ show_main_menu
+ local choice
+ local version
+++ get_git_revision
+++ local branch
+++ local latestTag
+++ local revCount
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=openHAB3
++++ git -C /opt/openhabian describe --tags --abbrev=0
+++ latestTag=patchday-20210316
++++ git -C /opt/openhabian log --oneline
++++ wc -l
+++ revCount=1251
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=9334918
+++ echo '[openHAB3]patchday-20210316-1251(9334918)'
++ whiptail --title 'Welcome to the openHABian Configuration Tool [openHAB3]patchday-20210316-1251(9334918)' --menu 'Setup Options' 18 116 11 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian project and this tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' 'Upgrade all installed software packages (incl. openHAB) to their latest version' '03 | Install openHAB' 'Install or upgrade to openHAB release 3' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basic openHABian setup ►' '20 | Optional Components' 'Choose from a set of optional software components ►' '30 | System Settings' 'A range of system and hardware related configuration steps ►' '40 | openHAB Related' 'Switch the installed openHAB version or apply tweaks ►' '50 | Backup/Restore' 'Manage backups and restore your system ►'
+ choice=
+ RET=1
+ '[' 1 -eq 1 ']'
+ return 255
+ system_check_default_password
+ is_pi
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ local algo
+ local defaultPassword
+ local defaultUser
+ local generatedPassword
+ local introText
+ local originalPassword
+ local salt
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ id -u pi
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ defaultUser=openhabian
+ defaultPassword=openhabian
++ grep -w openhabian /etc/shadow
++ cut -d: -f2
+ originalPassword='$6$EcUQdmL2e18B5nhi$UZYhLhUyjrrrBdZBHEl1SCU6EHNFnA59SdRb8BO8ssNeTqJLxgNjSdKTulBMlruq8N2rB95VgJVMC3uCEG/XW1'
++ echo '$6$EcUQdmL2e18B5nhi$UZYhLhUyjrrrBdZBHEl1SCU6EHNFnA59SdRb8BO8ssNeTqJLxgNjSdKTulBMlruq8N2rB95VgJVMC3uCEG/XW1'
++ cut '-d$' -f2
+ algo=6
+ introText='The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openhabian'\''!'
++ cut '-d$' -f3
+ salt=EcUQdmL2e18B5nhi
+ export algo defaultPassword salt
++ perl -le 'print crypt("$ENV{defaultPassword}","\$$ENV{algo}\$$ENV{salt}\$")'
+ generatedPassword='$6$EcUQdmL2e18B5nhi$46CzD8KTV67ui5bAxK4xdakzLZfRPVFZhO3Z45UqI7lIUeYNQrGZM/SeDVkCG.cFRnb1weQvjAg5Y/nh0Adz2/'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2021-04-11_21:31:34_AEST [openHABian] Checking for default openHABian username:password combination... '
2021-04-11_21:31:34_AEST [openHABian] Checking for default openHABian username:password combination... ++ id -u openhabian
+ [[ -n 1000 ]]
+ [[ $6$EcUQdmL2e18B5nhi$46CzD8KTV67ui5bAxK4xdakzLZfRPVFZhO3Z45UqI7lIUeYNQrGZM/SeDVkCG.cFRnb1weQvjAg5Y/nh0Adz2/ == \$\6\$\E\c\U\Q\d\m\L\2\e\1\8\B\5\n\h\i\$\U\Z\Y\h\L\h\U\y\j\r\r\r\B\d\Z\B\H\E\l\1\S\C\U\6\E\H\N\F\n\A\5\9\S\d\R\b\8\B\O\8\s\s\N\e\T\q\J\L\x\g\N\j\S\d\K\T\u\l\B\M\l\r\u\q\8\N\2\r\B\9\5\V\g\J\V\M\C\3\u\C\E\G\/\X\W\1 ]]
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -e '2021-04-11_21:31:34_AEST [openHABian] We hope you got what you came for! See you again soon ;)'
+ cd /home/openhabian
openhabian@openhabian:~ $ sudo openhabian-config
