because i am struggling with my current installation of OH3. (openhabian 2.5.11 - upgrade to RC - upgrade to 3.0.0 release maybe it will be a good idea to start from scratch again with openhabian 1.6.2.
Is there any guideline already for the migration from OH3 to another OH3 system?
I don`t want to get rid of the configuration i did within the last 2 weeks.
I am no openHABian user, so cannot really say.
Start updating your openHABian to the latest version and then select stable openHAB branch.
Do an openHAB upgrade in openHABian, which schould keep cor existing config.
Yes almost everything of importance:
to mention your openhabian version, your oh version, what you did and … what your problem is.
Guessing you have OH3 but are still on the OH2 branch, you will want to switch to the openHAB3 branch. And please explain what you did to end up like that. If you had selected menu 03 it should have switched branches, too.
Why? There’s no reason to think this is related. And you still didn’t answer most of my questions such as what you did to end up there and what your problem is.
You likely did not upgrade properly. Migrating should have you end up with the openHABian branch ‘openHAB3’. But you don’t even tell which one you are in now.
