helmar74
(Helmar)
September 14, 2020, 1:19pm
#1
Hello everybody,
currently I’m cleaning my system and I’m updating all my “old 1.x” Bindings to Version 2.5.8.
I found a solution for nearly every 1.x binding.
I’m also using the persistence bindings “rrd4j” and “mapdb”.
I use it mainly for statistics (diagrams in sitemap and habpanel) and for “initial values” after system start.
So my question is:
Will there be a version3 of this binding?
Do I have to change to a other persistence binding?
-> If so, which persistence binding should I use.
Thanks a lot
helmar
hmerk
(Hans-Jörg Merk)
September 14, 2020, 1:22pm
#2
rrd4j and mapdb persistence will be available in openHAB 3.0
helmar74
(Helmar)
September 14, 2020, 1:28pm
#3
OK, thanks for the info. Will the Binding than be upgraded from 1.14.0 to 3.x or will it still be possible to run the “old” 1.14 Bindings in OH3.x?
hmerk
(Hans-Jörg Merk)
September 14, 2020, 1:47pm
#4
Persistence has already been migrated to openHAB 3.0, there will be no option to run any openHAB 1.x binding in oH3.
helmar74
(Helmar)
September 14, 2020, 1:48pm
#5
OK, this means, that the following installed bindings, will be updated to 3.x when I update from 2.5.x to 3.x?
hmerk
(Hans-Jörg Merk)
September 14, 2020, 1:52pm
#6
Please check this thread
Hi all, .DEB and .RPM packages for openHAB 3 snapshots are now available. I’m going to use this space to detail what’s changing and how to use them. If anything changes with the packages I will update this post.
Note for openHABian users: openHABian has a few extra features such as zram that use openHAB 2 specific paths. If you want to try openHAB 3, you should disable ZRAM first and expect that there will be a few things (such as frontail) that will not work as you’d expect. Make sure you’ve u…
Upgrade existing configs from 2.5.x to 3.0 ist still on the roadmap afaik.
Apparently, rrd4j
is installed by default.
Here is the MapDB version.
helmar74
(Helmar)
September 14, 2020, 1:55pm
#8
OK, than I assume both persistence bindings will work after the upgrade…
