Hey guys,
As I updated my .items files using an external API, I found out that when I modify the file by adding a tag to an item (or removing it) resets the current state of the item to NULL
This is not a big issue if I do it on items that are persisted, but I ran into problems with items that can not be persisted using the JDBC Mysql
service.
Specifically, when trying to save data for Location
items, JDBC
shows a warning saying there is no way to generate the table for that item.
I tried some workarounds on this (saving item state as a String
and then persist the String
, then on System started
put the state back into my Location
item), but I hope there is an easier way to handle this.
