On OH3 restart I’m getting the following 2 messages 6 times. I think that it will tell me that persistence tries to get historic item data which is a string in the DB but the item now seems to be integer!?
I can’t remember if I changed items from string to int (number?) or when. I can access the database and could delete the wrong values but I don’t know how to find them!?
Can anybody help me how I can figure out which items in the database causing the error?
2022-11-18 17:03:48.203 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.jdbc.internal.JdbcPersistenceService@e1799e': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
java.lang.ClassCastException: class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.objectAsInteger(JdbcBaseDAO.java:544) ~[?:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.getState(JdbcBaseDAO.java:514) ~[?:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.lambda$0(JdbcBaseDAO.java:348) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:195) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.forEachRemaining(ArrayList.java:1655) ~[?:?]
at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484) ~[?:?]
at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474) ~[?:?]
at java.util.stream.ReduceOps$ReduceOp.evaluateSequential(ReduceOps.java:913) ~[?:?]
at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
at java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578) ~[?:?]
at org.openhab.persistence.jdbc.db.JdbcBaseDAO.doGetHistItemFilterQuery(JdbcBaseDAO.java:349) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcMapper.getHistItemFilterQuery(JdbcMapper.java:169) ~[?:?]
at org.openhab.persistence.jdbc.internal.JdbcPersistenceService.query(JdbcPersistenceService.java:205) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor133.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2022-11-18 17:03:48.235 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'jdbc': class java.lang.String cannot be cast to class java.lang.Integer (java.lang.String and java.lang.Integer are in module java.base of loader 'bootstrap')
