I’m new to persistence, I will make a log of my rain sensor, for each hour, day, week
I use OH2 and I think a need to use the historicstates, but I am really not sure.
So I need help for build the persist, rule and I item files.
I have some items, Oregon_RainTotal counting up all the time then it is rains one message for 0,5mm rain, so this number can´t be used for anything, but you can count how many inputs there has been the last hour,day,week.
I did find this code on this site, but I don’t know if this is the right code for my job.
Number Oregon_RainTotal "Total rainfall [%.2f mm]" (Rain)
Number Oregon_RainTotal_H "Rainfall Hour [%.2f mm]" (Rain)
Number Oregon_RainTotal_D "Rainfall Day: [%.2f mm]" (Rain)
Number Oregon_RainTotal_W "Rainfall Week: [%.2f mm]" (Rain)
and then I have this rule I found, dont know if it can work for me
rule "Rain Total Changed"
Time cron "* 0/1 * * * ?"
// Post totals update
Oregon_RainTotal_H.postUpdate(Oregon_RainTotal.deltaSince(now.minusHours(1))
Oregon_RainTotal_D.postUpdate(Oregon_RainTotal.deltaSince(now.minusDays(1))
Oregon_RainTotal_W.postUpdate(Oregon_RainTotal.deltaSince(now.minusWeeks(1))
I know anything about persistence but I can see that I need something to get this to work
I’m using rrd4j. However I have no experience in using historicstates with rrd4j, that migth no function.
But I’m sure you do need a working persistence in order to use historicstates!
I have no experience with persistence so I don’t know how to write the persis file, can I use something else instead of the historicstates to give me the log data?
That depends on what you actually want to display.
In your case (RainFallSince…) I’d think you will finally need something like the historic states.
However I’d start by creating a working peristence.
Read through the docs (for rrd4j the OpenHab1 docs are still valid) and try to start your persistence. When encountering any problems just ask again.
Note: Just checked on my persited item (rrd4j database), the call:
MyItem.deltaSince(now.minusDays(1),“rrd4j”)
worked! Output was “0.0100000000000000088817841970012523233890533447265625”
Should this code make a connection to a specific rrd4j .persise file, how is this done!
Could you show your persise file, and the full rule file, because I get nothing with this code
What have you done so far in order to start persisting?
Load the rrd4j persistence service via PaperUI. (I guess yes)
Configure rrd4j via the persist and config files in order to tell what and how often to persist and to configure how the values and how many values are kept inside the database. (I guess not)
MyLogger.def=GAUGE,90,0,3,60
MyLogger.archives=MAX,.5,1,1440:MAX,.5,5,2016:MAX,.5,15,2668
MyLogger.items=MyItem1, MyItem2,…
That configures rrd4j to saved my Items in three archives wich cover a day (euch minute), aber Werk (5 minute steps) and 4weeks(15 Minute steps).
so far I have done this, with no output on my 4 rain total items
my items:
Number Oregon_RainTotal_H "Regn seneste Time [%.2f mm]" (Vejrst)
Number Oregon_RainTotal_D "Regn seneste Dag: [%.2f mm]" (Vejrst)
Number Oregon_RainTotal_W "Regn seneste Uge: [%.2f mm]" (Vejrst)
Number Oregon_RainTotal_M "Regn seneste Minut: [%.2f mm]" (Vejrst)
Number Oregon_RainTotal "Total regnfald [%.2f mm]" (Vejrst) //sensor mm total
my rules:
Time cron "0 * * * * ?"
Oregon_RainTotal_H.postUpdate(Oregon_RainTotal.deltaSince(now.minusHours(1),"rrd4j")
Oregon_RainTotal_D.postUpdate(Oregon_RainTotal.deltaSince(now.minusDays(1),"rrd4j")
Oregon_RainTotal_W.postUpdate(Oregon_RainTotal.deltaSince(now.minusWeeks(1),"rrd4j")
Oregon_RainTotal_M.postUpdate(Oregon_RainTotal.deltaSince(now.minusMinute(1),"rrd4j")
rrd4j.persist:
// persistence strategies have a name and a definition and are referred to in the "Items" section
Strategies {
// for rrd charts, we need a cron strategy
everyMinute : "0 * * * * ?"
everyHour : "0 0 * * * ?"
everyDay : "0 0 0 * * ?"
everyWeek :"0 0 0 0 * ?"
Items {
Oregon_RainTotal : strategy = everyMinute
// vim: syntax=Xtend
rrd4j.cfg:
MyLogger.items=Oregon_RainTotal
#That configures rrd4j to saved my Items in three archives wich cover a day (euch minute), aber Werk (5 minute steps) and 4weeks(15 Minute steps).
I see you are using my setup of rrd4j.
This setup is used for data that isn’the summed up like your rain data. Make sure the values are summed up elsewhere.
Also my rrd4j database will not hold any data older then 4 Weeks!
So, finally the persistence is working somehow.
First thing to note, you only get one value every 4 minutes stored. Using the settings you posted above it should be every minute ( which is needed for rrd4j)???
In your rule, put in some lines of login for in order to have printouts in the log.
Something like:
Hi
I have data coming in to my Oregon_RainTotal_H item now so it’s working now, so maybe _D and _W is comming as well.
How do I change the time from 4min to 1 min?
Isn’t this 1min “0 * * * * ?”
Do you know how to read the time stamp in the rrd file because this “time”: 1492381680000 makes no sense
Presently I have no idea why your setup (which is as you posted my setup of rrd4j) is saving only at a 4 minute step. That isn’t done in the Rules! It is set in the .persistence file as the strategy.
The timestamp is in milliseconds counted from a starting point (which I don’t know/care). The difference between consecutive values should be 60000 for minute steps.
