Phantom actions in Somfy Tahoma binding things
  • Platform information:
    • Hardware: AMD/8Mb RAM/SSD 512Gb PCIe3
    • OS: W10Pro
    • Java Runtime Environment: Zulu Java 17
    • openHAB version: 4.1.1.
HI all
I have been experiencing for weeks some let’s say “phantom” actions in Tahoma binding things. They are some curtains and blinds that repently move down with no specific rules in OH UI, at random times, sometimes in the morning other in the afternoons. THey are Somfy IO and RTS.
In spite there are no rules making this actions, these are the logs generated from these “phantom” actions:
2024-04-21 11:39:52.657 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'PersianaDormitor2_Controlsilent' updated to 49
2024-04-21 11:39:52.658 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PersianaDormitor2_Controlsilent' changed from 0 to 49
2024-04-21 11:39:52.658 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'PersianaDormitor2' updated to UNDEF through PersianaDormitor2_Controlsilent
2024-04-21 11:39:52.658 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'PersianaDormitor2' changed from 0 to UNDEF through PersianaDormitor2_Controlsilent
2024-04-21 11:39:52.658 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'PersianaDormitor2_Control' updated to 49
2024-04-21 11:39:52.658 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PersianaDormitor2_Control' changed from 0 to 49
2024-04-21 11:39:52.659 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Dormitorio2' updated to UNDEF through PersianaDormitor2
2024-04-21 11:39:52.666 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'PersianaDormitor2' updated to 49 through PersianaDormitor2_Control
2024-04-21 11:39:52.666 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'PersianaDormitor2' changed from UNDEF to 49 through PersianaDormitor2_Control
2024-04-21 11:39:52.667 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Casa' updated to UNDEF through Dormitorio2
2024-04-21 11:39:52.667 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'PersianaDormitor1_Controlsilent' updated to 47
2024-04-21 11:39:52.667 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PersianaDormitor1_Controlsilent' changed from 0 to 47
2024-04-21 11:39:52.667 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'PersianaDormitor1_Control' updated to 47
2024-04-21 11:39:52.667 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'PersianaDormitor1_Control' changed from 0 to 47
2024-04-21 11:39:52.669 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'PersianaDormitor1' updated to 47 through PersianaDormitor1_Control
2024-04-21 11:39:52.670 [INFO ] [hab.event.GroupItemStateChangedEvent] - Item 'PersianaDormitor1' changed from 0 to 47 through PersianaDormitor1_Control
2024-04-21 11:39:52.670 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'PersianaDormitor1' updated to 47 through PersianaDormitor1_Controlsilent
2024-04-21 11:39:52.670 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Dormitorio2' updated to UNDEF through PersianaDormitor2
2024-04-21 11:39:52.671 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Dormitorio1' updated to UNDEF through PersianaDormitor1
2024-04-21 11:39:52.671 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Casa' updated to UNDEF through Dormitorio2
2024-04-21 11:39:52.671 [INFO ] [openhab.event.GroupStateUpdatedEvent] - Group 'Casa' updated to UNDEF through Dormitorio1
2024-04-21 11:39:56.732 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'StoreCocina_Control' updated to 97
2024-04-21 11:39:56.732 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'StoreCocina_Control' changed from 20 to 97
2024-04-21 11:39:56.737 [INFO ] [openhab.event.ItemStateUpdatedEvent ] - Item 'StoreCocina_Control' updated to 100
2024-04-21 11:39:56.738 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'StoreCocina_Control' changed from 97 to 100
Any ideas to solve this?
Thank you and regards
Diego
anything that is exposed to the internet so that every that finds the exposed UI can play games with it ?
Hi
I don`t know how my OH UI could be exposed, but any recommendations to improve the security are welcome.
Thank you!
Did you open a port on your router so that you can access the UI from the internet ?
Certainly I had two ports that I created for openhab (don’t remember why) but were not open. I have just deleted them.
I normally use android app to go into UI either through internet or my local network, but I guess that it should not be a problem.
That depends - if you use myopenhab.org that’s fine. If you opened a port to access your openhab installation via internet that could be the problem.
I have always used myopenhab.org as remote server for the android app, since is what I learnt about how to use it remotely from the beggining, and I am a compliant boy :smile: :wink:
I think that I openend a port in the router to try to solve a problem with smarthomej/Tuya binding, keeping a reccomendation of one OH post. I was trying to control a Tuya dimmable RGWB lighbulb creating a thing in OH by means of this binding but finally it was not possible, and the port remained there in the route. I tried also using amazon alexa binding, with no success. Now I am fighting with MQTT, but I am affraid that there are still many things I don’t understand properly. :grimacing: :crazy_face:
The port is definitelly closed, so let’s see what happen from now on. :upside_down_face:
Regards
Diego
